Activity › Forums › Adobe After Effects › Swap Content on the Timeline?
  • Swap Content on the Timeline?
    Posted by Sam Swenson on October 1, 2007 at 1:55 pm
    I am producing a project that I’d like to set up as a project template.
    What is the most efficient way to set it up so I could swap content out to produce a separate version from the same template?
    Some assets on the timeline utilize masks and I am looking for a way to not have to re-apply all of the masking/keyframes/effects etc.
    Also, is there any way to use XML to control what assets are placed?
    Forgive the broad questions 🙂 Any help would be greatly appreciated.
    Sam
    Sam Swenson replied 19 years ago 3 Members · 3 Replies
  • Aharon Rabinowitz
    October 1, 2007 at 2:21 pm
    I don’t know nothin about XML, but I do know somethin about swappage…
    OK here’s the deal –
    In the time line, select the piece of footage you want to swap
    In the project panel, select the footage you want to use as the replacement
    Begin dragging it down onto the time line, and once you start doing that, hold down the Alt (or option) key.
    Making sure you are over the time line (where the names of each footage item in the comp is listed), With the Alt key still held down, let go of the footage (let go of the mouse button)
    You will see that your footage has been replaced.
    Aharon Rabinowitz
    arabinowitz(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
  • Lifetypo
    October 1, 2007 at 7:14 pm
    after spending like 12 hours on a project
    (my first ae project i did)
    then i found some better quality footage of the same video i was using . i thought i was going to have to redue the entire thing . or rename my new HQ footage same name as old footage then reopen ae… but nope when i found the replace footage option i was so happy . thank goodness for the replace footage option . ive used it so many times .
  • Sam Swenson
    October 1, 2007 at 7:18 pm
    Great! I’ll give it a try.
