Activity Forums Adobe Premiere Pro Swap AE Footage
  • Swap AE Footage
    Posted by Scott Gene on August 14, 2008 at 10:54 pm
    I was working in AE, saved my current project as another name (sequencial save numbers), then continued creating in AE.
    When I open up Premiere, how in the world can I easily swap the composition from AEprojectver1 to AEprojectver2?
    Do I have to manually re-add all my AE comps because I’m doing sequential saving in AE?
    It’s a royal pain to have to redo all my Premiere cross transitions. blah.
    Scott Gene replied 18 years ago 3 Members · 3 Replies
  • Jon Barrie
    August 15, 2008 at 2:34 am
    rename it back to the one you were using before it should all update happy. Of course the DL function can’t find the stuff it’s looking at the project based on its disk/location/name. Why are you using Incremental saves and then not save as at the end with the same name so the DL can work with it?
    – Jon 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Steven L. gotz
    August 15, 2008 at 8:30 pm
    The solution to saving as you go along is not to “Save As” because that causes you to work in a new file name. The solution is to use “Save a Copy” instead. That gives you a backup, but keeps the current project’s name the same for use with Dynamic Link.
    However, to answer the original question, it is simple. Just select the new dynamic link comp in the project bin, the select the dynamic link in the sequence. Right click on the comp in the sequence and choose “Replace with Clip” and “From Bin”.
    Simple.
    Steven
    https://www.stevengotz.com
  • Scott Gene
    August 28, 2008 at 2:37 am
    Thanks gents. Excellent. Found the bin replace option. Nice.
    And I was saving as a different name because I’m a dunce. 😉
