Activity › Forums › VEGAS Pro › SVP14 H.265 Very Poor Performance Performance
  • SVP14 H.265 Very Poor Performance Performance
    Posted by Matthew Jeschke on May 31, 2017 at 4:15 am
    I have a decent editing machine. And Sony Vegas Pro 14. I’m trying to edit clips from my DJI Phantom 4 Pro captured in 4k 30fps h.265. The clips play perfectly find in Windows Media Player… However, they barely play if I try to JUST preview them in Sony Vegas Pro 14. My Machine isn’t a slouch either…
    M.2 Samsung 512mb main drive
    1TB Samsung Capture Scratch Drive (clips on here)
    Intel i7-5930k Processor
    64gb ram
    Radeon RX480
    I’d think Vegas would at least play back the clips okay? Is there some setting that’s wrong? I have vegas configured for:
    32GB Dynamic Ram Preview
    12 maximum render threads (2x the number of CPU cores).
    Any tips? I’m assuming SVP uses it’s own encoder / decoder for h.265? Is there a way to upgrade / update it… I’m guessing it’s running CPU only and not utilizing the GPU but just a guess.
    Any tips greatly appreciated. Hardly plays in even draft preview mode.
    I do Architectural Photograph & Cinematography as a part of being a Residential Real Estate Consultant.
    Some of my work can be seen at,
    https://www.youtube.com/keystoaz/
    https://www.vimeo.com/matthewjeschke/
    https://www.keystoaz.com/
    PS. It\’s an excellent excuse to ride off what I love, Camera equipment 🙂
    Matthew Jeschke replied 8 years, 12 months ago 5 Members · 18 Replies
  • 18 Replies
  • Graham Bernard
    May 31, 2017 at 4:46 am
    You raise an interesting, my word, conundrum: Media that can be played in a Media Previewer should also be Preview-enabled within an NLE. Am I correct?
    Can you access “other” media that plays in your Media Player and VP14? I’m guessing you can. But let’s check it anyway.
    Can you supply information about that Media? Use the MediaInfo s/w and report back here.
    My guess is that VP14 is choking on that Media because of a CODEC mismatch and/or bitrates are too high for the VP Project Settings and the Media Player isn’t. Trying to confirm any of this will require you to do some more dectective work so we could possibly assist you.
    Interesting.
    * Grazie
  • Matthew Jeschke
    May 31, 2017 at 6:02 am
    I see several data points you need me to collect to troubleshoot. Let me know if I got what you mentioned. Thanks a million for the help.
    Quite note, the entire timeline lags even if I have lower quality videos, that normally play well in a timeline (e.g. h.264 1080p). It doesn’t matter where I playback from, a point in the timeline with lower quality clip or the h.265 clip. Also the project renders fine… It’s just timeline playback that suffers.
    1. Project Settings
    2. Information on Media
  • Graham Bernard
    May 31, 2017 at 6:07 am
    Try matching your Vegas Project Settings to the Media.
    * Grazie
  • Matthew Jeschke
    May 31, 2017 at 6:38 am
    I already tried that. It had no effect… when i started the project i told it to match the project settings to that clip. I later reduced the project resolution :/
  • Graham Bernard
    May 31, 2017 at 6:48 am
    OK, now the 32-bit Floating point. Is there a reason you have that selected?
    * Grazie
  • Graham Bernard
    May 31, 2017 at 7:18 am
    Woah! Nice piece of kit there.
    https://www.dji.com/phantom-4-pro/info
    There are MANY formats. Here’s your options for H.265
    H.265
    C4K:4096×2160 24/25/30p @100Mbps
    4K:3840×2160 24/25/30p @100Mbps
    2.7K:2720×1530 24/25/30p @65Mbps
    2.7K:2720×1530 48/50/60p @80Mbps
    FHD:1920×1080 24/25/30p @50Mbps
    FHD:1920×1080 48/50/60p @65Mbps
    FHD:1920×1080 120p @100Mbps
    HD:1280×720 24/25/30p @25Mbps
    HD:1280×720 48/50/60p @35Mbps
    HD:1280×720 120p @60Mbps
    Can you tell us what Bit Depth you have captured in? – You can see this in MediaInfo SHEET or TREE view.
    * Grazie
  • Graham Bernard
    May 31, 2017 at 7:19 am
    H.265
    * Grazie
  • Graham Bernard
    May 31, 2017 at 7:21 am
    If you haven’t already, try disengaging GPU Acceleration.
    * Grazie
  • Ole Kristiansen
    May 31, 2017 at 8:31 am
    Maybe Vegas pro 14 don’t like dji phantom h.265 mp4 – try with mov !
  • Matthew Jeschke
    May 31, 2017 at 5:08 pm
    Thanks for the help and things to test. Didn’t seem to have much of an effect. Here’s what I got:
    1. 32-bit floating point: Tried with 32-bit video levels & 8 bit. No performance difference for either
    2. Bit depth captured in:8-bits
    3. GPU Acceleration OFF: I turned it off. All the non h.265 clips suffer, but h.265 clips play about the same. My theory is the encoder / decoder for SVP is not utilising the GPU…. Why I have no idea ☹
    4. Try with MOV files: I have captured everything in MOV container. Will test MP4 when I get a chance.
    I’m considering trans coding the h.265 to perhaps ProRes or NDxHD. Is this a good idea? What would be another container they could be put in that wouldn’t throw out quality?
    Of course I’d rather just fix SVP if I can 🙁
