Activity Forums VEGAS Pro SV8-Expanding layered audio track
  • SV8-Expanding layered audio track
    Posted by Randal Radabaugh on December 29, 2010 at 4:39 am
    Hello again.
    well everything says right click header and expand track.
    I have Vegas Pro 8 and this does not seem to be an option.
    I have looked, clicked, right clicked event,track and cannot find this.
    I have tons of audio tracks that are layered and I want to split them up for use in sound editing to video.
    Some have drum tracks, or harmonies, or melodies, and I really need to
    split the layers so I can adjust each layer in the track.
    2 layers show up in time line on a single track so I know Sony sees the layers. So, again how, where is the Expand function?
    Thank you.
    Mike Kujbida replied 15 years, 9 months ago 2 Members · 3 Replies
  • Mike Kujbida
    December 29, 2010 at 4:51 am
    [randal radabaugh] “well everything says right click header and expand track.
    I have Vegas Pro 8 and this does not seem to be an option.”
    Stop looking because it isn’t an option.
    Did you import it as a veg file?
    If yes, that’s why you’re only seeing a single stereo audio track.
    The trick here is to right-click on the timeline and select Edit in Vegas (ProjectName.veg).
    This will open a new instance of Vegas that has all the tracks (layers) that exist in the original project file.
  • Randal Radabaugh
    December 29, 2010 at 12:24 pm
    Not not .veg file.
    I have either premade scores, tracks I make or import wav (usually)
    I think Sony sees it as stereo-see end of post.
    They show in timeline the two separate tracks per clip on 1 track line.
    there will be a audio track on top half of Vegas track and one on bottom half..I can see both track layers on the 1 track.
    Tracks I make I can just record single tracks and add( dont like this idea) but the scores-and precomposed tracks i do not have the original track layers.
    But- I did discover that you can right click on the clip, and
    turn off half of it- left or right and end with a single layer.
    Dont know how this will affect as far as pan- prolly only get left or right channel.ATM my left Audio channel is Broken(connector)
    So I guess I got to go the hard way with it.more splice, dice and
    fuss. thanks.
  • Mike Kujbida
    December 29, 2010 at 3:01 pm
    [randal radabaugh] “I have either premade scores, tracks I make or import wav (usually)
    I think Sony sees it as stereo-see end of post.”
    Unless it’s a specialty score where you have the option of breaking it out to individual instrument tracks, then yes, that’s what happens.
    [randal radabaugh] “Tracks I make I can just record single tracks and add( dont like this idea)”
    Why not?
    In a recording studio, everything is recorded to it’s own independent mono track.
    The mix to stereo or 5.1 is the final step in the process.
    [randal radabaugh] “So I guess I got to go the hard way with it.more splice, dice and
    fuss. thanks.”
    Unless you have access to independent tracks, the hard way is all you can do 🙁
