Activity › Forums › Apple Final Cut Pro › Sustaining a music chord
Posted by Brian Thomas on April 26, 2020 at 5:05 pmI have a piece of music but the last chord is cut off a bit abruptly. Is there a way of sustaining (making longer) that chord using FCPX (or some other software) so that I can do the fade myself?
Near Geneva, Switzerland
Tangier Clarke replied 6 years, 4 months ago 4 Members · 4 Replies -
Jeff Kirkland
April 26, 2020 at 9:04 pmProbably the only way is to grab a section of the chord that works as a loop and paste it a few times. Sometimes it works, sometimes it doesn’t. It all depends what’s happening musical in and around the chord. Alternatively, you might throw a bit of reverb on the last note to add some sustain and a longer decay to fool the ear into thinking the final chord lasts a bit longer than it does.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland -
Evan Fitzer
April 27, 2020 at 12:43 amBrian, I’m wondering if this might be of some use…a handy little tutorial from an episode of Mac Break Studio from the guys at Ripple Training…
https://www.youtube.com/watch?v=uismrA-h6tM&list=PLj5Nh9NxSxdlDLI_z-GBII8_vTXD7J5AL&index=143&t=0s
Evan Fitzer
Kamloops, BCSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Brian Thomas
April 27, 2020 at 3:42 pmThanks SO much for the ideas gentlemen – much appreciated. I tried all sorts of different lengths of loops cut in slightly different places and I used a good selection of effects but there was always an underlying echo sort of sound to one degree or another. You know what I hit on in the end – I just retimed the actual chord to 50% of the normal speed. It kept the pitch (of course) and sounds perfect! Really happy, clever FCPX!
Tangier Clarke
April 27, 2020 at 4:12 pmI’ve had this issue several times in projects where I just needed that last note or chord to hold a little longer. No amount of features in FCP X did what I needed to make it sound natural. Ultimately I went into Logic Pro X, recreated the sound for that one note or chord (as close as possible/passable), exported the audio file, then imported/edited that into my cut. Each situation may be unique though depending on the note/chord being played and for how long in the original, along with the attack on those notes.
