Activity Forums Boris FX Sapphire surround an object with glow
  • surround an object with glow
    Posted by Bodybuildingbs on June 29, 2005 at 3:22 am
    Okay..
    two quick questions.
    I have some footage and I want the glow to surround a mask when a person pulls it out of the bag..I am using after effects and when I apply the glow it appears to affect the entire scene…please advise.
    The other question is how do you keep the glow tracked as the hero brings the mask up to examine it?
    Thank you.
    Doug Lowe replied 21 years, 1 month ago 4 Members · 5 Replies
  • Peter Wiggins
    June 29, 2005 at 10:43 am
    What is your host app? Avid, FCP, AE?
    Peter
    https://www.peterwiggins.com
    At Wimbledon editing for ESPN
  • Gary Oberbrunner
    June 29, 2005 at 1:42 pm
    Hi, Jack. You’ll need to roto or key your mask (I’m guessing this is a “face mask”, a real object, not an AE Mask). Once you’ve done that, use S_Glow and use the Mask layer as the Matte input of S_Glow.
    Here’s a step-by-step; this is just one way, experienced AE users probably know some tricks to speed this up.
    Put your video into a new comp; name it MaskMatte (it’ll end up as the matte for the hero’s mask). Add a new solid white layer. Make it invisible, but select it. Draw the outline of the object you want to glow with the pen tool; you’ll see it turn white at this point. Keyframe that Mask over the whole shot. Now turn off the source layer so you only see the white-on-black matte. (Feather it a little if you like.)
    Make a new comp now with just the video — this is going to be the final comp. Drop the MaskMatte comp into it and make it invisible. Add S_Glow to the video track, and in its Matte dropdown, select your MaskMatte layer. Voila, your glow tracks the object!
    Let me know if you have any questions, and anyone else feel free to jump in with other ways to do this!
    — Gary Oberbrunner
  • Bodybuildingbs
    June 29, 2005 at 3:18 pm
    After Effects 6.5
  • Bodybuildingbs
    June 29, 2005 at 3:19 pm
    Will try and thank you. Yes it is a face mask.
  • Doug Lowe
    August 27, 2005 at 1:44 am
    So how would I do that same thing with Avid Xpress Pro, Boris Red, and Sapphire?
