surplus tracks when importing a clip.
Posted by Peter Popovici on August 19, 2010 at 12:17 pmHI, when importing a new clip in Sony Vegas the clip has a 2nd surplus audio track underneath the normal audio one, overlapping additional audio tracks. If I delete the 2nd surplus audio track of the imported clip whole clip gets deleted. Please advice me how to import a normal 1 video/1 audio clip only, everything went fine till something I can’t figure must have been changed, that screws all.
Have all a nice week-end.
Peter Popovici replied 16 years ago 2 Members · 6 Replies -
Mike Kujbida
August 19, 2010 at 12:42 pmCan you provide a screenshot?
Do you mean that there’s a completely separate audio track in addition to the regular one?
How are you capturing (firewire or some other method)?
What kind of footage are you capturing? -
Peter Popovici
August 19, 2010 at 1:10 pmThank you MIKE, always very kind… How can I provide you a screen shot? I import a regular clip from my p.c. folders, I cannot see the meaning of “firewire” method, sorry MIKE…, clicking the “open” yellow folder upper left, and additional 3-5 AUDIO tracks pop up underneath the normal single ONE, obstructing my audio track that contains the film music. Deleting all surplus tracks works (but it’s not a normal situation!!!), only the 1st additional ONE once I delete him all footage gets deleted.
I’m capturing (you mean importing?) m2ts AVCHD files, it worked perfect up to this day. -
Mike Kujbida
August 19, 2010 at 2:03 pmPeter, to provide a screenshot, click the “Image upload” icon just above the reply screen (3rd from the right) and follow the prompts.
That probably won’t be necessary though as I suspect that what you’re importing is a 5.1 clip and not a stereo one.
Is your project set to stereo or 5.1 audio?
I don’t deal with AVCHD files here so all of this is a stab in the dark for me. -
Peter Popovici
August 19, 2010 at 2:53 pmHey MIKE, Yes! you solved it – your instinct is accurate =), experimenting in Properties audio tab I changed the “stereo” to “5.1 surround”.
You made me curious to ask you, a professional, if no AVCHD what type of files you work with?
Also, the “5.1” audio is better sounding then the “stereo” one?Thank you again MIKE, another kind help from you!
Mike Kujbida
August 19, 2010 at 3:13 pmPeter, I’m glad to hear that my guess turned out to be correct.
The community college I work for still has (due to budget constraints) broadcast-grade miniDV camcorders.
They are good ones ($20K when originally purchased several years ago) so we work with what we have.
This means that I’m still standard definition 4:3 when the rest of the world is high-def 16:9 🙁
5.1 (aka surround sound) should, in theory anyway, sound better.
Audio is not my strength so I leave that to my co-worker who is an audio engineer.
