Activity Forums Adobe After Effects Surfing Footage Effects
  • Surfing Footage Effects
    Posted by Matthew Barge on August 2, 2008 at 12:22 am
    I’m trying to apply filters to footage of surfing to make some really cool-looking surfing videos. One of the things I’m trying to do is take video of a surfer, color the surfer and his board all white, and color everything else black. I have tried a number of methods.
    Vectorize Color Filter in FCP6 gets close but does not give me proper outline of the surfer and board
    Magic wand in Photoshop frame-by-frame takes way too long and hand-painting is not consistent enough
    I cannot get the Track Motion feature in After Effects or Motion to apply an effect to the moving object. I can track the motion of the surfer in After Effects and Motion, but I cannot apply any effect to the motion track nor to the exact shape of the surfer and his board
    Please help! I will send stills of what I am talking about. I am making a next-generation surf video and have spent tons and tons of hours researching and still cannot find the solution. This post is a last-ditch effort. Any help with this effect or cool unusual ideas that might work with surf footage would be very much appreciated, thanks
    Matthew
    Jack Leto replied 18 years, 1 month ago 2 Members · 3 Replies
  • Jack Leto
    August 2, 2008 at 10:18 am
    There’s a couple of ways to approach this, here’s one;
    you’ll key out the ocean and create a matte. once the matte is created you can apply effects to one side without affecting the other. you may need to take a couple of passes at it but this is what we do =)
    MOTIONOLOGIST
  • Matthew Barge
    August 2, 2008 at 6:06 pm
    What exactly do you mean by key out the ocean and create a matte? I have been working with the 8-point matte but it is almost impossible to get the matte perfectly around the surfer. Thanks so much for replying, I really appreciate the help 🙂
    Matthew
  • Jack Leto
    August 2, 2008 at 8:42 pm
    Basically you would cut out the surfer from the ocean using a color keyer (like ‘keylight’). Barend has a great tutorial on the process of matte creation:
    https://library.creativecow.net/articles/onneweer_barend/keyingtut.php
    thats another way to approach it, by rotoscoping. yes you would need more points, use the pen tool to create your shapes.
    I would break up the rotoing to the major shapes of the body. torso, right upper arm, right fore arm, left upper arm..etc..(so a dedicated animated mask per part) and keyframe every 5 or 10 frames.
    It’s hard to tell what would be the best path to go without seeing the footage.
    There may be a filter that can do what your describing. But I believe these two ways would give you the most control over what you want the surfer or the ocean to look like without affecting the other.
    MOTIONOLOGIST
