Activity › Forums › Blackmagic Design › Supported motherboards/chipsets for Decklink
Posted by Andrey Obodnikov on April 25, 2008 at 7:15 amGood day everybody,
Is there any way to know which new chipsets/motherboards are supported by BMD, because their sertified list is a little bit old. For example is the P35 chipset supported, X38 chipset, S5000 chipset ? For example we assambled station based on S5000XVN and Decklink SP PCIe and having problem with booting. So what is more reliable maybe you have some information.
Chris Johnson replied 17 years, 9 months ago 3 Members · 4 Replies -
Aristides Tiropolis
April 27, 2008 at 7:18 pmCheck this thread out
https://forums.creativecow.net/thread/124/867601#867603
X38 will not have problems. Chipset problems were apparent mostly in the plain PCI era where latency etc. issues plagued VIA and nVIDIA chipsets.
Going with desktop motherboards is, I should say always a Hit or Miss situation. There’s always “something” that may go wrong for instance, bad bioses, blue screens, memory incompatibilities, bad eSATA controllers (JMicron – stay away!)The lot…
I managed to have a stable system (Quad Intel) which is very quick in renders, editing, Photoshop etc. But the next one will be a MAC pro. I’ve had it.
Additionally I would suggest going with a newer 3 slot PCIe desktop motherboards(1 that’s 16 lanes and 2 that are 8 lane) So you’re able to put another card in i.e Fiber Channel.
You could always go for maybe a MAC Pro, or Server motherboard.
I hope this helps.
Andrey Obodnikov
April 28, 2008 at 6:39 amThank you for your responde. And what about server motherboards it’s 100% supermicro ? 😉 I explain. We sell decklink cards to our customers for automation software, cg software, I0 card for Macs, sometime for PC’s. So i need a PC that will be working 24 hours a day in a rack, so it’s gonna be servermotherboard, Decklink will be used as output card for Infocaster that will perform as standalone Info channel. So i’m just looking for reliable chipset or serverboards that i can purchase from intel or from supermicro. This 2 vendorers are most popular in our country, so there are no problems with deivery. Any suggestions for Server MB ?
Aristides Tiropolis
April 28, 2008 at 12:47 pmThe only one I think is a quite a good deal is this one:
https://www.supermicro.com/products/motherboard/Xeon1333/5100/X7DCA-L.cfm
Because of the 3 PCIe (1 x16 & 2 & x8)slots. and the ATX (Standard PC Case) form factor
Other than that I find Supermicro’s products to have a rather limited range, I mean why isn’t there a 3 PCIe x16 motherboard? They only have a 5 x8 which means you cannot even install a standard Graphics card.
I would suggest looking again at MAC Pro’s they have AMAZING expandability and server class motherboards plus they support PCIe 2.0 and the latest 1600 FSB Xeons. You can always buy a Quad and upgrade later to 8 core or more memory.
Chris Johnson
November 12, 2008 at 3:08 pm
