Activity Forums DaVinci Resolve Supported Decklink Drivers for version 8.
  • Supported Decklink Drivers for version 8.
    Posted by Marcus Smith on July 4, 2011 at 3:31 am
    Hi guys,
    Was wondering if the recommended Decklink drivers for version 8 is still 7.9.5.
    I can’t see any notes about it in the config guide or on the support Website.
    Marcus.
    David Austin replied 15 years, 2 months ago 4 Members · 3 Replies
  • Sascha Haber
    July 4, 2011 at 7:53 am
    More important, what should we do regarding the Decklink firmware upgrade ?
    Right now 7.2.1 does not work with the firmware the 8 rc1 installed.
    Am I doing something wrong ?
    A slice of color…
    DaVinci 7.1.2 OSX 10.6.7
    MacPro 5.1 2x 2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Luke Maslen
    July 6, 2011 at 1:52 am
    Hi Marcus,
    The Resolve installer installs the drivers for your DeckLink card. Please do not install separate drivers for the DeckLink card as it will likely cause problems in Resolve. If you have already run a DeckLink or Desktop Video installer, please run its Uninstall utility and then reinstall the latest version of Resolve. This will install the drivers you need for use with your DeckLink card.
    Regards,
    Luke Maslen
    Blackmagic Design
  • David Austin
    July 11, 2011 at 7:25 pm
    I have a bit if a problem with that. I use the Decklink for video output from Pro Tools and Resolve on the same mac ( not at the same time) Installing Resolve 8 killed the PT output. Anything I can do?
