Activity › Forums › Storage & Archiving › Support for HP LTO drive
  • Support for HP LTO drive
    Posted by Bob Cole on January 10, 2013 at 12:57 am
    I am looking for tech support for my HP Ultrium 920 external LTO3 drive. I’ve done all I can with new tapes, new cables, cleaning, HP diagnostic software, and can’t get it to record more than about 200 mb before calling for a new tape and reporting the need for cleaning.
    I bought this drive from HP Direct. But when I look for support on HP’s website, I am totally stymied. The site requests my address, then recommends a couple of inappropriate network vendors far from my office in Baltimore, MD.
    Is there a good independent source of hardware support, anywhere in the U.S., for these drives? It was not a cheap drive, and I have only run about 90 tapes through it.
    Bob C
    Tim Jones replied 13 years, 8 months ago 2 Members · 3 Replies
  • Tim Jones
    January 10, 2013 at 3:06 pm
    Try starting at this link:
    https://h20565.https://www2.hp.com/portal/site/hpsc/public/psi/home/?sp4ts.oid=4150338
    That should get you further into the support system.
    How long have you had the drive? The warranty on these drives is 3 years, so if it’s less than 3 years old, HP will replace it for you. If over 3 years, you’ll need to get it repaired.
    HTH,
    Tim
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Bob Cole
    January 10, 2013 at 4:12 pm
    Thanks Tim. For some reason that link didn’t work, but I’ll keep trying it – is there a way to search to find that page?
    The drive is just over 4 years old. I see on eBay that I can get a “new” slide-in replacement for the drive (using my existing “toaster box” which turns it into an external drive) for under $700.
    Bob C
  • Tim Jones
    January 10, 2013 at 4:39 pm
    I got there by going to:
    https://www.hp.com/support/, entering Ultrium 920 as the product, and then drilling … Their site is definitely not the most intuitive :).
    I also found this number so that you can call with your serial number and see what they can do for you:
    800-334-5144
    Identify the drive to them as a “Storageworks Ultrium 920 Internal” and that should get you to the correct division.
    Tim
    Tim
    Tim Jones
