Activity › Forums › Adobe After Effects › Supper Detailed Images
  • Supper Detailed Images
    Posted by Dk on May 11, 2005 at 7:45 am
    When animating images in AE that are high resolution, but contain large amounts of close integrate detail, the images will always render with weird scan lines or jittery pixels – what can be done as a work around? Any good techniques? I’m tried various things but have not been able to produce good results. Thanks for your help.
    -dk
    Filip Vandueren replied 21 years, 4 months ago 2 Members · 1 Reply
  • Filip Vandueren
    May 11, 2005 at 12:31 pm
    Try the “reduce interlace flicker” or another slight blur on your layer, and possibly also on an adjustment layer ontop of your composition.
    I’m assuming you’re outputting to a television screen, where vertical details of less than 2 pixels will flicker.
