Activity › Forums › Blackmagic Design › Supermicro bios version and decklink HD pro compatibility
Posted by Manuel Deo on June 28, 2006 at 9:16 amHI blackmagic team,
i have a supermicro MOBO X6dae-g2, do you think the version 2.0 of bios can create^probleme with decklink hd pro card???
because, i have no video input in the hd pro, howewer, the card works well, just a probleme with the input videoThank
MAnuel
Manuel Deo replied 20 years, 1 month ago 2 Members · 4 Replies -
Stewart Mayer
June 29, 2006 at 2:44 amI’ve got the same motherboard and the hd pro single link card and am having no bios related problems with the latest 2.0 bios.
stewart
Manuel Deo
June 29, 2006 at 7:39 amhi stewart,
Thanks for your answer.
I looking for a solution of my problem of no video input detect by hd decklink pro.So, your decklink card works good with supermicro MoBo x6dae-g2, can you telle me if you use the bios default configuration, or have you doing special configuration ??
I acknowledge being exceeded by my “no video input” problem.
thanks
Manuel
Stewart Mayer
July 1, 2006 at 7:15 pmI’m not doing anything special in the bios. Have you made sure that the speed of the PCI-X slot is at 100 or 133mhz? If you have it in the wrong slot, and a slower pci-x card is using the same “bus” then the whole bus slows down. I had a firewire 800 card that slowed my hd card slot down to 33mhz, but changing the slots around fixed the problem. You can check the manual to find out which slots are dependent on each other.
Other than that, I don’t know.
Good luck,
stewart
Manuel Deo
July 4, 2006 at 7:48 amhi stewart,
My pci x bus works at 133 Mhz, and i have take out all other card on my PC.Just the decklink and my ATI graphic card was in the computer.
And the problem stays ” No video input”
I have install another decklink car ( The decklink Pro ” and there is the same problem.
So, i don’t know where is probleme, my Mobo ? The drivers? The windows OS??
It’s frustated to don’t know where is the origin of this problem
Thanks for your help
Manuel
