Superman titles
Posted by Sean Stringer on July 5, 2006 at 10:27 pmHey everyone-
I’m looking at doing something similar to the opening Superman titling effects from any of the Superman movies.
Does anyone know of a good tutorial for something like that?Sean Stringer replied 20 years, 2 months ago 2 Members · 6 Replies -
Jon Okerstrom
July 6, 2006 at 2:32 amWell, I haven’t seen the latest movie or any other Superman movie for quite a while…
However, if you’re talking about text along an arc with animated z depth, that’s really pretty easy for Invigorator. Be more specific about what you’re trying to achieve and we’ll try to help.
Jon
Sean Stringer
July 6, 2006 at 1:30 pmThanks Jon-
The titles appear as a semi transparent with a small amount of depth to the letters, which I can do.
But then what they do is zoom/stretch towards the audience and then you kind of fly through the them and then they fade.
I can adjust the depth of the lettering but not to the extent of what’s needed.
Man I hope that makes sense?If you are open to it I can email you a small clip from one of the movies for reference.
thanks again…
Jon Okerstrom
July 6, 2006 at 5:08 pmYou can adjust the z of the objects (depth) beyond the slider. Just type in a bigger number.
You can also do the fade in a number of ways.. using overall transparency of the layer, layermapping a fade movie to the transparency channel, or by using the cascading transparency effect in ProAnimator 4.
Does this help?
Jon
