Activity › Forums › Adobe After Effects › Superman Titles
Superman Titles
Posted by Samuel Graves on July 28, 2008 at 4:05 pmThis is what i’d like to achieve:
https://www.youtube.com/watch?v=ZBvUUU00IX4Ideas anyone?
John Stanowski replied 18 years, 1 month ago 4 Members · 3 Replies -
Jerry Renes
July 29, 2008 at 7:53 amHi Samuel,
I tried something out and it’s definitely going to work with the ECHO effect. Check out this quick 5 min work test video:
https://www.renessance.nl/supermantitles.mp4
You can just create an outline of the text using illustrator or photoshop. Import it to your project. Just animate the text the way you want. So change the text or camera position. (or scale up the text)
Apply the ECHO effect to the text layer and set Keyframes for the number of echo’s. play around with the opacity of the text layer to get the “shine through effect”
Turn on the motion blur for more realism, and you’re done!
Good Luck!
Inacio Nehme
July 29, 2008 at 1:41 pmI am not sure, but maybe the have used boris FX w. a different material and just animated the extrusion and position…
John Stanowski
July 30, 2008 at 10:07 amYou many not need to make your text in AI or Photoshop, try making text with an outline and no fill. Add a glow to your text.
Yes, use repeater, and try the Add blend mode.Aaron Rabinowitz (sorry if I spelled it wrong, Aaron) just did a tutorial on the Repeater effect, so it should get you up to speed on that effect.
The rest is just tweaking and those fancy camera moves. I’m not sure but I hope the repeater effect is 3D so you can get those changes in perspective.
