Activity Forums DaVinci Resolve Superimposing a clip with itself for “post-conform” Composite Mode effects?
  • Superimposing a clip with itself for “post-conform” Composite Mode effects?
    Posted by Robert Glanns on September 5, 2011 at 5:35 am
    Is it possible to superimpose a clip/event over itself AFTER you import an FCP XML-based sequence into Resolve?
    Id like to create a soft-diffused look, and want to be able to go into the Conform page, and simply copy the clip over itself, and add an Add or Screen composite mode on the upper clip. But I cant seem to find an easy way to do this besides finding the clip in the Media Pool and manually editing it onto a new track.
    Is there not a simple “copy clip” feature in Resolve? Or is the Composite Mode feature only really intended to support incoming Composite Modes from an external FCP XML sequence?
    Vladimir Kucherov replied 15 years ago 7 Members · 7 Replies
  • 7 Replies
  • Glenn Sakatch
    September 5, 2011 at 3:53 pm
    You don’t actually “copy” the clip. How i’ve done it is razor the clip so it is now in two parts. Move one part up a layer. Then trim both parts back to their original lengths. Turn on screen comp mode on the upper clip.
    Glenn
  • Mike Most
    September 5, 2011 at 4:40 pm
    Very clever workaround! I’ve got to try that.
  • Charly Stone
    September 5, 2011 at 7:39 pm
    Why not copy/paste ?
    It would be so intuitive.
  • Glenn Sakatch
    September 6, 2011 at 1:16 pm
    Doesn’t seem to allow you to copy and paste.
    Glenn
  • Dimitrios Papagiannis
    September 7, 2011 at 6:21 am
    Just a note. I have done this on clips in the timeline. I have used this technique in other programs and wanted to use it in Resolve. In the other programs I had access to a transparency control to vary the amount of the effect I wanted blended with the original clip. In Resolve I basically accomplished the same thing by using the Luma controls for what I wanted. If any one knows of another way to control the transparency of a clip in the timeline please let me know.
  • Sascha Haber
    September 7, 2011 at 1:30 pm
    1. Add a second track
    2. Do your thing on the footage in there.
    3. Add an alpha output
    4. Add an empty node in the end and connect it to the alpha.
    5. Use PostMixGain for transparency
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Vladimir Kucherov
    September 7, 2011 at 9:58 pm
    It feels like the elegant way to implement this would be using the new 2nd RGB input (made if I understand correctly for Epic HDRX right now) – just a 2nd node stream, and then all we’d need is the layer mixer node to support blending modes.
