Activity › Forums › Apple Final Cut Pro › Superimpose footage on FCPX
  • Superimpose footage on FCPX
    Posted by Chad Mackenzie on November 12, 2012 at 8:00 am
    I saw a skateboard ad on TV where the skateboarder was grinding down a rail but it was live action. It’s super imposed but I was wondering if I would use composition? I figured I would need a solid wall background. I’ve been testing this technique but can’t figure it out completely. I put the same footage on different layers, then cropped it, but there’s a color difference I noticed, even though the footage is all the same (I copied and pasted), there’s a slight color difference.
    Then maybe I was thinking compositing it but that doesn’t seem it would work either.
    It’s actually similar to this but I want to use live action: https://www.skateboardingmagazine.com/action-sports-photography-launch-ramp-skateboard-ollie-stop-motion/
    Andreas Kiel replied 13 years, 10 months ago 3 Members · 2 Replies
  • Olof Ekbergh
    November 12, 2012 at 2:07 pm
    Sounds to me like you are trying to Key footage. Sometimes called chroma key (typically against solid even blue or green BG), Motion does a good job of this as does AE.
    It can be tricky to light a chroma key correctly, do some research.
    There are ways of keying against a stationary background as long as the camera is on sticks and not moving, and the background is static, I use AE for this.
    Olof Ekbergh
  • Andreas Kiel
    November 13, 2012 at 7:31 pm
    Looks more like a difference key like in AE.
    -Andreas
    Spherico
    https://www.spherico.com/filmtools
