Activity Forums Compression Techniques SUPERB COMPRESSION What did they use and how did they use it?
  • SUPERB COMPRESSION What did they use and how did they use it?
    Posted by Ralphsturg on May 7, 2006 at 2:34 am
    OBSOIVE:
    https://www.emichrysalis.co.uk/quicktime/sigur_ros/glosoli/index.php?version=7.020&bandwidth=150000
    This six minute music video is somehow only 16 megs or so and is quite high quality… Does anyone know how this was compressed? I am trying to export a 5 minute video at the same dimensions, I am exporting a 1280 x 545 uncompressed video file to h264 codec at about 6400kbps and it doesen’t look that good and is 50 PLUS megs. All the H264 exports are a heck of a lot brighter than the actual file, why is that? The blacks in the original file are much darker and richer and the h264 export. (I’m using quicktime pro for export by the way) everything is brighter and the colors are washed out… does anyone know how the aforelinked video was createD? What compression tools methods did they use to pull this off? I’m interested in posting trailers and shorts and I like that size and framing and that compression! 16 megs for a beautiful 6 min video is a dream, does anyone know what kind of magic they used to pull this off? Any help would be MUCh appreciated!
    Craig Seeman replied 20 years, 4 months ago 2 Members · 1 Reply
  • Craig Seeman
    May 8, 2006 at 3:15 am
    The Cinema version is indeed H.264 but
    frame size is 640×272
    File size is 48.18 MB
    Data Rate is 1079.42 kbps
    frame rate is 25fps (PAL)
    Could it have been shot with Varicam or CineAlta or maybe even film (but then why not keep it at 24fps instead of 25fps PAL?)? There’s certainly a lot of good color grading evident. Keep in mind a good compressionist may use processing filters for best viewing on a computer monitor. Also keep in mind high quality source has significant impact on end result quality. HDCAM SR source is going to look much better than DVCAM source given the same compression settings.
