Activity › Forums › Adobe Premiere Pro › Super Yellow Footage Disaster. H.E.L.P.
  • Super Yellow Footage Disaster. H.E.L.P.
    Posted by Cosette Saliba on February 10, 2020 at 8:43 pm
    Hello Community!
    It is my first-time post to the community because usually, I find answers to what I am looking for, however this time I got a huge problem.
    To Premiere and Color Correction geeks out there, this is for you!
    I shot a 30 min footage, and the lighting was terrible (YELLOW YELLOW YELLOW). I did a small test first and color corrected in Premiere and it was fine. However, the lighting turned out much more yellow than I thought and I can’t get to fix it!
    I included screenshots of the original footage, plus my failed attempts at fixing it. But I still can’t get the right white balance, the right exposure, and the film turns grainy and low resolution. I watched everything available about this, however, no one had footage that is as yellow and dark as mine. I played around with white balance, curves, color shadows highlights and midtones… nothing seems to work.
    Another problem is the screen behind me, but I think (hope) I can fix that with chroma key…
    Is there a way to save my footage?
    Thank you so much ❤ ❤ <3
    Original image
    Failed attempt 1
    Failed attempt 2
    Failed attempt 3
    Chris Wright replied 6 years, 7 months ago 2 Members · 3 Replies
  • Chris Wright
    February 11, 2020 at 3:51 am
    and 3d white balance like here.
    https://youtu.be/R3WFaWx-pS4
    track 1 – global hue adjustment
    track 2- duplicate video track, track key luma with hue adjustment to fix just highlights
    track 3- duplicate video track as guide layer for track 2 hue
    track 4 – global 3-D white balance
    you can use hue v hue or track the face separately for more tweaking
    any grain left over, use neatvideo.
  • Cosette Saliba
    February 11, 2020 at 7:51 pm
    Thank you so much Chris for your reply.
    Actually, I’m a beginner so I got stuck at track 2…and even the video was not easy for me to follow.
    I tried playing around with Hue vs Sat and it got much better (check below)
    I know it still needs tweaking, any further simple things I can work on?
    Thank you again!
  • Chris Wright
    February 12, 2020 at 4:10 am
    hue v sat? fascinating… it must have had too much chroma in certain hues.
    there’s more than one way to skin a cat in this one, good job.
    btw. did my white balance video help?
