Activity › Forums › RE:Vision Effects › super slow motion without pauses
  • super slow motion without pauses
    Posted by Jordan Yaruss on January 19, 2009 at 5:24 pm
    I’m trying to slow down some existing regular-speed footage a whole lot using After Effects with Twixtor. The problem I’m running into is that, even though it’s interpolating frames, there’s still a longer pause on each real frame. I’ve tried non-Twixtor pixel motion and frame blending, too. I don’t care if it turns into a blurry mess; The important thing is that it’s just smooth. Can I do that?
    Pierre Jasmin replied 17 years, 8 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    January 19, 2009 at 8:18 pm
    EG: If you are slowmo by a factor of 3X with blend mode, and working in frame mode, you could instead of going from frame 0 to 99, type 0.17 (half of 1/3) to 99.17 then you will never fall on a full frame.
    Any way you can send a project and 10 source frames to techsupport at revisionfx dot com or if too big use the form on our website in support section (to ask support questions) and it will return an ftp site.
    Pierre
