SUPER Slow Motion in SMS9
Posted by Jamie Moore on September 9, 2010 at 8:17 pmI understand how to drag out a clip to make slow motion in SMS 9.. My questions is can I make it slower?
Here is a sample of a slow motion shot with an arrow while hunting wild pigs on my farm. This is as slow as I can make it.
https://www.youtube.com/watch?v=ez5W8BmPMIo
I am assuming I can not make it any slower because my video is shot with an FX1 and it is 1080i and the interlacing is the issue.
Can someone give me there thoughts?
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Edward Troxel replied 16 years ago 4 Members · 11 Replies -
Mike Kujbida
September 9, 2010 at 10:18 pmHere’s two suggestions for you.
The first is to shoot it with as high a shutter speed as the available light will allow you to do.
I shot some race cars at the Detroit Gran Prix a number of years ago.
It was a bright sunny day so I had my shutter at 1/2000.
Slow motion was crystal clear, to the point where I could see the tire tread instead of it being a blur.
I’ve also shot hummingbirds this way and the wings can now be seen instead of being a blur.The second involves using a nested veg.
Load a clip onto the timeline, slow it down as much as possible, save it as a veg file, import this veg file (now called a nested veg), add it to the timeline and slow it down again.
Because you’re not actually rendering it out, there’s no image quality loss.
Repeat again if necessary. -
John Rofrano
September 9, 2010 at 11:21 pmThe second involves using a nested veg.
Unfortunately he is using Movie Studio 9 which doesn’t support nested projects. It would have been more obvious had he spelled out SMS9 as Sony Movie Studio 9. 😉
The other option, of course, is to render the slow-mo footage, bring it back into Movie Studio and slow it down again. Repeat as necessary.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Jamie Moore
September 9, 2010 at 11:30 pmThe sutter speed was @ 1/6000 I believe.. I’m not sure that that makes any difference in reference to the slow motion..Or does it?
Man, I have to render then slow down again.. Not a ton of work but what a PITA..
What form should I render to keep the best quality of the clip?? The final desination is a short video…Maybe I’d only have ro render once and reslow it down to achieve a little more slow motion
John Rofrano
September 10, 2010 at 2:07 amMan, I have to render then slow down again.. Not a ton of work but what a PITA..
If you had the Pro version you could add a velocity envelope and slow it down 12x. Then if that wasn’t enough you could do as Mike said and drop it into another project as a nested project and slow it down 12x again (which is 12 x 12 = 144x!) Usually one nesting is slow enough or in your case just the 12x might be slow enough.
If you just have to render once you can render back to HDV. If you needed multiple renders I would suggest using Cineform but I realize that as a Movie Studio user Cineform cost more than Movie Studio probably did ($99 USD).
You could render to Huffyuv or Lagarith. Both of those codecs are free and lossless so you can re-render all you want and not loose quality. The trade-off is that they render extremely large files because they keep all of the quality. You can Google for them. Once installed the will show up under Video for Windows after pressing the Custom button (that’s assuming the Custom button will work in Movie Studio because I know it’s grayed out sometimes)
~jr
Jamie Moore
September 10, 2010 at 3:17 amYou guys are great.. Really appreciate the info.. I’ll install the lagarith codec and give it a try.. I do have the custom options in Movie Studio Platinum 9 Pro which is specifically what I have.. If not I’ll try just rendering the clip then putting it back in..
Sounds like my desires for certain features is already reaching its limits in SMS…
John Rofrano
September 10, 2010 at 10:21 amSounds like my desires for certain features is already reaching its limits in SMS…
Well… you do have a $2,000+ FX1 prosumer camera… I think it might be time to spring for the equivalent software. 🙂
~jr
Edward Troxel
September 10, 2010 at 1:54 pm -
Jamie Moore
September 10, 2010 at 2:27 pmhaha.. I get the same response when I pull the FX1 out of a duffle bag..
Can I pick your brain for two more items..
1) Regarding color corrections- I assume that I should do no color corrections to the small, rendered clip, until the composition is complete and the entire edit is finalized and corrected, correct?
2)When I rendered the small clip then applied the additional slow motion I get a ton of blurryness when the pigs move..I’m not sure if its just the preview or if thats the way it will render in the final process. Is there a way to smooth that with that I have?
John Rofrano
September 11, 2010 at 1:28 amSpeeding up can go up to 12x. Slowing down, a single Velocity envelope can slow down to 0% (freeze frame).
lol, what was I thinking? You’re right Ed, in fact, a velocity can slow it down past zero into backwards! 😉 Thanks for the correction.
~jr
John Rofrano
September 11, 2010 at 1:32 am1) Regarding color corrections- I assume that I should do no color corrections to the small, rendered clip, until the composition is complete and the entire edit is finalized and corrected, correct?
Yes, I would leave color correcting until after the slow-mo.
Make sure that your preview is set to best Full in order to see what the final video will look like more accurately. If you still see blurring, it may be the blending of frames to get more frames that didn’t exist to make it play slower. This is unavoidable.
~jr
