Activity Forums Compression Techniques Super long compressor time (over 100 hours!)
  • Super long compressor time (over 100 hours!)
    Posted by Andrew Dubatowka on September 1, 2011 at 12:29 am
    Hello All,
    I am compressing a 14 minute HD timeline from FCP using Apple Compressor. When I start the compressor the remaining time starts at about 2 minutes and continues to increase. I allowed the compressor to run for over 24 hours and the progress bar didn’t even get one third of the way and the remaining time was over 100 hours.
    Any idea why this is taking so long? PLEASE HELP!
    Here are my settings (which I got from a Vimeo HD compressor tutorial):
    Name: Vimeo HD new
    Description: No description
    File Extension: mov
    Estimated size: 571.81 MB
    Audio Encoder
    AAC, Stereo (L R), 44.100 kHz
    Video Encoder
    Format: QT
    Width: 1280
    Height: 720
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Selected: 29.97
    Frame Controls: Off
    Codec Type: H.264
    Multi-pass: On, frame reorder: On
    Pixel depth: 24
    Spatial quality: 75
    Min. Spatial quality: 25
    Key frame interval: 30
    Temporal quality: 50
    Min. temporal quality: 25
    Average data rate: 5.12 (Mbps)
    David Bauman replied 15 years ago 2 Members · 1 Reply
  • David Bauman
    September 2, 2011 at 3:02 pm
    Have you tried going to the compressor menu under “file” and clicking, reset background processing? Also check your batch monitor first to make sure nothing else is running. If it is, or if it’s just sitting there, listed as canceled, I’d try resetting the background processing.
