Activity › Forums › Apple Final Cut Pro Legacy › Super Duper Or Carbon Copy
Posted by Patrick Morrow on February 16, 2008 at 3:27 pmI need to reinstall my Os, does anyone have a preference between these two backup utilities? I heard Time Machine will not do all I need it to do.
Thanks!!!
Patrick MorrowLee Mceachern replied 18 years, 7 months ago 5 Members · 7 Replies -
Jerry Hofmann
February 16, 2008 at 3:33 pmI really like SuperDuper!… really like it.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
David Mcgiffert
February 16, 2008 at 4:21 pmI use Carbon Copy Cloner (CCC). I think SuperDuper is really good too.
SuperDuper seems to add updates more often then Carbon Copy Cloner,
if that is of any value, I don’t know.I just used CCC to make a bootable clone of my Tiger hard disk.
I took the firewire drive that the clone was on down to ProMAX
for them to put onto the Intel dual core…etc. they were configuring
for me.
I wanted two partitions; one with my old drive (with FCS original installed on it), and another partition with a new OSX Tiger install with FCS2 on it. I am in the middle of a project and wanted to be able to use both versions of FCS and migrate over carefully.CCC worked perfectly and while I have had a few teething ‘opportunities’,
I am very happy with how the change-over has gone.
I also am quite sure I could have had the same good results with SuperDuper.fwiw,
David
Jeremy Garchow
February 16, 2008 at 5:35 pmI used to CCC now I SuperDupe. CCC was the first and the best, then development fell behind a bit due to rsync or something for Tiger.
I switched to SuperDuper after that. They both work and CCC has long sincew been ‘fixed’.
The latest version of SuperDuper let’s you do a bootable clone right next to your Time Machine backup. Pretty Sweet if you plan on using Time Machine.
Lee Mceachern
February 16, 2008 at 6:52 pmI’m firing up a new Leopard unit and have not dabbled yet with Time Machine. Is time machine not good enough? What more do I get out of Super Duper or CCC?
Lee Mceachern
February 16, 2008 at 7:14 pmI just looked back a ways in this forum and found the answer to the question I just posed.
— Don’t believe everything you think.
Jeremy Garchow
February 16, 2008 at 7:18 pmCCC and SUperDuper make bootable clones, meaning you can choose the disk as a startup disk and boot from it. handy when you have different variations of a system such as Quicktime versions or capture card drivers or whatever. Time Machine does not make a bootable clone, it just stores info from different points in time and can restore your disk back to that point in time. Actually I just looked on SuperDupers website and they pretty much sum it up:
https://www.shirt-pocket.com/blog/index.php/comments/times_arrow_redux/
Jeremy
Lee Mceachern
February 16, 2008 at 9:41 pmThanks, Jeremy. You tightened up my understanding nicely!
Lee
