Activity Forums Adobe After Effects Super annoying masking issue
  • Super annoying masking issue
    Posted by Malcolm Desoto on July 11, 2011 at 3:36 pm
    so, I’m doing a lot of rotoscoping and every once in awhile I come across an issue where I can’t click and drag to select multiple mask points. Instead, when I click and drag, it moves the actual clip. I don’t know if it’s something I inadvertently click or what but it slows things way down and is really annoying!
    runawaykitee.blogspot.com
    “The secret to creativity is knowing how to hide your sources.” –Albert Einstein
    Barend Onneweer replied 15 years, 2 months ago 2 Members · 2 Replies
  • Malcolm Desoto
    July 11, 2011 at 4:16 pm
    Oh! duh du duh! I should have thought of that
  • Barend Onneweer
    July 11, 2011 at 9:14 pm
    Personally I prefer to animate masks in the Layer Window instead of the Comp Window, and having them side-by-side. You can’t move the layer accidentally. But more importantly:
    I disable the visibility of masks in the Comp Window so I can see an uncluttered edges, to see how the masked foreground behaves against the background.
    And by disabling ‘render’ in the Layer Window while masking I can see the entire image – not just what’s within the mask. I prefer masking that way, to judge where the edges are. But because the Comp Window is open also can still see the final result.
    Barend
    Raamw3rk – digital storytelling and visual effects
