Activity Forums Adobe Premiere Pro Super 8 cine film
  • Super 8 cine film
    Posted by Doug Helsby on December 17, 2009 at 3:18 pm
    I have just found some old cine 8 film which I have loaded into Pro. Has any one gots some tips on how to improve the quality of the film?
    Doug
    Doug Helsby replied 16 years, 9 months ago 3 Members · 11 Replies
  • 11 Replies
  • Darren Edwards
    December 17, 2009 at 4:05 pm
    Super8 is the latest codec to be supported? 😉
    Seriously speaking, what’s so bad about the original rushes?
    Darren.
    youtube.com/darrenpce
  • Doug Helsby
    December 17, 2009 at 4:29 pm
    Darren
    My kids do not have a cine 8 projector and so I thought it would be good for them to see their innocence by putting the film onto DVD.Now I have to convert .dat into mpeg for Pro to read. The disk that I originally burnt the cine onto by way of Pinnacle, which converts analogue to digital, saved them as .dat files to view through Nero.A simple task made more complicated again!!!!
    Doug
  • Darren Edwards
    December 17, 2009 at 7:33 pm
    How did you telecine the Super8 stock with Nero in the first instance?
    D.
  • Doug Helsby
    December 18, 2009 at 8:55 am
    Darren
    I do not understand telecine with Nero.I simply found the cleanest matte white card I had ,projected against it, whilst at the same time, videoing it with HD camcorder. The results were much better than I expected. I have started to edit in Pro and the evidence so far is that the camcorder has produced images on a par with the origional. I am looking to improve,(tweak) within Pro the quality if I can. As a newbie to Pro I have still to learn its capabilities.
    Doug
  • Mike Velte
    December 18, 2009 at 11:02 am
    Try Auto Levels with a small amount of Smoothing.
  • Darren Edwards
    December 18, 2009 at 11:11 am
    Ah, okay. That’s not an uncommon practice. There’s
    currently a big furor about the ‘WWII in HD’ doco series
    because they up-rez’d a lot of library film by pointing
    a Red One at a wall…
    https://provideocoalition.com/index.php/shullfish/story/controversial_history_channel_wwii_in_hd_debate_the_truth/
    Colour grading in Prem can be equally as sophisticated
    as anything else out there.
    If the footage is a bit murky, the first thing I’ll adjust
    is pedestal. This raises the overall brightness/gamma
    levels in a sympathetic manner whilst (hopefully) revealing
    hidden details in the black areas. And vice versa if lowered.
    Curves will crunch your levels whilst also increasing contrast.
    Almost every tutorial here — or at places like
    https://www.videocopilot.net/tutorials/ — will have something
    to say about curves adjustment, and how to do it. Go easy.
    There’s a fantastic old-school method of sharpening imagery
    in Photoshop, which up until CS3, was impossible to do with
    video footage, but now that CS3+ versions of Photoshop support
    video import, one can use the Photoshop filters on it.
    *It derives from the days when Quark users wanted a way of
    shrinking images whilst maintaining sharpness…
    Import the video, duplicate the video layer, apply Filter/Other/High Pass
    and select a Radius setting of around 0.5 (the higher the figure the
    sharper the effect). After which layer blend the effected top
    layer with Hard Light. Works great on still images, of course,
    but for video footage in Photoshop you will need to do this
    frame by frame. Prem’s sharpening filters are a bit clunky,
    a bit low bit-rate, for me — but, any port in a storm.
    To really go to work on your Super8 stuff, grab a copy of
    Magic Bullet’s latest Looks suite plugin for Premiere. The user
    interface is a joy to use.
    https://www.redgiantsoftware.com/products/all/magic-bullet-looks/
    Alternatively, you can have my Super8 projector.
    Hope that helps.
    Cheers,
    Darren.
  • Darren Edwards
    December 18, 2009 at 11:13 am
    Never use Auto Levels for anything! It’s a horrible, horribly
    unintelligent filter which hasn’t a clue what it’s doing
    and will result in flickery footage. Very serious about this.
    Darren.
  • Doug Helsby
    December 18, 2009 at 1:07 pm
    Mike
    Thank you I will give it a try.
    doug
  • Mike Velte
    December 18, 2009 at 6:53 pm
    I agree with Daren, Auto levels is bad for video, but for some strange reason it works well with video of film which flickers badly on its own and Levels makes it worse…try it…mikey likes it!
  • Darren Edwards
    December 18, 2009 at 8:33 pm
    I didn’t mean any disrespect to Mike, of course – if he’s experienced positive results by applying Auto Levels to film captured via HDV camera, then go for it. However, my one and only time using it was applying it to music promo performance shot on a beach in Barcelona; the light remained the same throughout and its director wanted a crunched/saturated look, and Auto Levels seemingly did the trick, quickly. It was applied to all the live stuff, we awaited render and found it a waste of time. Whenever tentatively applied at a later date on other types of footage, the result was the same: flickery, unuseable garbage.
    D.
