Activity Forums Adobe After Effects Expressions sunrays or RAYS effect
  • Andrew Kramer
    November 28, 2005 at 9:40 am
    Use the checkerboard effects and make it so that one is very long. then use the corner pin distortion effect to skew into one direction.
    Good Luck.
    Andrew
  • Chris Zwar
    November 28, 2005 at 5:41 pm
    Create a square composition, add vertical stripes (either use the grid plugin, or just add some solids, or even the checkerboard plugin and mosaic set to 1 vertical block), then use the polar coordinates plugin. Set the polar co-ords to “rect to polar”, which is the opposite of the default, and make it 100%.
    -Chris Zwar
    Motion Graphics Designer
    Will animate for food
  • Tomadonna
    November 28, 2005 at 7:48 pm
    Hi guys,
    How do you get the lights to have that gradient effect?
  • Ryan Hill
    November 28, 2005 at 11:01 pm
    Effect > Render > Ramp
