Activity Forums Adobe After Effects Sun Streak Recreation
  • Sun Streak Recreation
    Posted by Angel Nieves on June 25, 2010 at 2:59 am
    Does anyone have a good technique to create a sun streak to the girl’s hair on the top picture, to match the sun streak she has on the bottom picture (right side)? I need to do it for continuity purposes. I tried a couple of things in After Effects but nothing good enough. Thanks
    Joseph Pole replied 16 years, 2 months ago 4 Members · 5 Replies
  • Tudor “ted” jelescu
    June 25, 2010 at 6:57 am
    Not knowing what you tried I’m gonna go with the first thing I would do: duplicate layer, draw mask, play with levels or curves and warm photo filter.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • David Johnson
    June 25, 2010 at 11:36 am
    A variation of the same method, you could also duplicate the layer, feather mask out everything you want unaffected, use a blending mode like add, screen or soft light and adjust the opacity of that layer.
    You could also use an effect like CC_Beam (I think that’s what it’s called) on an adjustment layer and tweak the effect controls and/or adjustment layer’s properties as needed.
  • Joseph Pole
    June 28, 2010 at 8:40 am
    Shouldn’t be too difficult Angel.
    I did a quick example and took a screen grab for you. For ease i have made reference to the layer names in my project/screen grab. For clarity, i have enhanced the effect so that it is more visible but less realistic (turn the opacity down on the additive layers in your version to make it more realistic.)
    Duplicate the layer. (GIRL HIGHLIGHT LGE)
    Make a small feathered mask for the highlighted area.
    Switch the layer mode to add.
    Add a colour balance to that and adjust until the colours match
    Duplicate GIRL HIGHLIGHT LGE
    Reduce the size of the mask to make a smaller, more intense central highlight
    Adjust the opacity of both highlight layers until it looks natural
    i also made a precomp (SHINE) and masked ares of the original shot to emulate light streaks. in the main comp (SUN HIGHLIGHT MAIN…
    make the SHINE layer additive
    add shine to it
    move the shine source point up and right outside of the image area to crate directional sunlight streaks
    that should get you started. a small amount of a lens flare glow, matching the grades etc will also help.
    http://www.josephpole.com
  • Angel Nieves
    June 28, 2010 at 5:59 pm
    @ Tudor Ted: The photo filter worked nicely. Thanks.
    @ Joseph Pole: Nice job. Thanks for all the work. Your hints are helpful.
  • Joseph Pole
    June 29, 2010 at 1:59 am
    if she moves significantly rotoscoping will of course be needed but that wasn’t the question.
