Activity › Forums › Lighting Design › summer sun
summer sun
Posted by Craig Alan on August 5, 2006 at 1:03 amI need to filter the blaring sun. I was hoping to just shoot an outdoor dramatic scene and interview by waiting for the magic hour but the timing has proven difficult. And the magic hour hasn
Craig Alan replied 20 years, 1 month ago 3 Members · 4 Replies -
Leo Ticheli
August 5, 2006 at 1:17 amUnfortunately, what you are looking for does not lend itself to a one-man band. Anything large enough to cover more than a close up face shot requires a huge overhead frame and silk with very sturdy support. Any wind and you’ll quickly discover some sailing lessons. These rigs take a lot of time to erect and require a good sized crew to man them.
There is a very simple solution to your problem, however. Just carefully choose your locations and time of day. Low sun falling on the subject’s back will solve the squinting problem and give you a beautiful 3/4 backlight. Avoid shooting when the sun is high and overhead and don’t shoot with the sun falling on the subject’s face and in their eyes.
A small reflector can help you paint the face hotter on one side to add three dimensionally. If you can find a pure white one, a popup automobile sunshade will serve very well at very low cost.
Good shooting!
Leo
Craig Alan
August 5, 2006 at 3:50 amThanks Leo,
I did not occur to me to use the sun as a backlight rather than the key light. I -
Tony
August 5, 2006 at 3:25 pmAll the variable you describe are working against you and the results will show it.
Try making the job easier and consider shooting your subject on a chroma key backdrop and shoot the sun plate later. Combine the two together later in post.
Some of the most effective sunset shots in movies are either chroma key effect shots or huge backdrops shots.
Craig Alan
August 5, 2006 at 5:07 pmThanks Leo,
