Activity › Forums › Adobe After Effects › sumi-e effect in after effects
Posted by Amz370 on February 4, 2006 at 9:10 amok several question in one
ok im trying to now creat a sumi-e effect like in photoshop, now first and easiest, how do i creat this if after effects?
is there a way?
ok so if there is no way, what is the proper format to transfer video to photoshop so i can drag and drop the sumi-e effect onto it and bring it back as video into a.e. or what have you to export as a quicktime vid.
thanks
-Aaron
Kathlyn Lindeboom replied 20 years, 6 months ago 4 Members · 5 Replies -
Amz370
February 4, 2006 at 9:11 amsorry for the extra posts, my computer was messing about, i apologize,
Todd Morgan
February 4, 2006 at 12:27 pmWhat is sumi-e?
Todd Morgan
Creative Director
Freelance F/X Inc. -
Mike Clasby
February 4, 2006 at 6:23 pmTake your video clip in AE and render it our with either Filmstrip (flm) or a
Ctrl M, then in the Render Queue, Output Module>Custom, then in the Output Module, In that top dropdown choose filmstrip (filmstrip is my fav, it’s all one file in PS, so apply the filter once and you’re done. If you want to vary the PS filter setting over the frames, you need to choose a Photo Sequence, like PNG sequence (this gives you a series of photos, one for each frames that you then can batch process in PS)(people like PNG because it supports transparency).
In that Video Output section, in Channels, be sure and select RGB + Alpha (that will give you Millions of Colors +, that + is necessary if you want transparency around an object) .Anyway hit render, then import your flm or Photosequence in PS, apply filter, then re-import into AE.
Note: You can save some time on the re-import by hitting the twirly (Main Render Queue again, then in Post-Render Action, choose Import and Replace Usage from the drop down.
Note: If you like that Render setting and you’ll use a lot, make a template out of it, from that first dropdown in the Render Queue, just below Custom choose Template, name it, and then you can choose it quickly later.
I apologize it this is too much detail.
Amz370
February 5, 2006 at 12:55 amno not to much at all thanks,
and sumi-e is a japanese paint style that is also a very intresting effect when applied in photoshop, as it looks like each shot is hand drawn
Kathlyn Lindeboom
February 5, 2006 at 1:07 amOK, I know that Japanese style is not the same as Chinese, but Joe Chao sent us a Chinese Style Painting Effect Tutorial that you might get some ideas from:
https://www.creativecow.net/articles/chao_joe/chinese_painting/index.html
It’s kind of a hand drawn, water color look.
Kathlyn Lindeboom
The Mistress of Mmmooooo!
