Activity Forums Apple Motion suggestions on emitters
  • suggestions on emitters
    Posted by Sarah on September 25, 2005 at 4:58 pm
    Hey everyone, newbie to motion with a tight deadline looming, doing a job that requires a bit of graphics to tie it up, I need to replicate a bottle of whiskey to give the effect of rising sales, is there a emitter in motion that I can use to replicate image of a whiskey bottle, or has anyone any other suggestions
    Thanks in advance
    Sarah
    Doyle Rockwell replied 20 years, 11 months ago 4 Members · 4 Replies
  • Noah Kadner
    September 26, 2005 at 12:54 am
    Depends how many shots you’ve had. Seriously though- could you be a bit more specific as to what you’re looking to do. There is definitely not a whiskey bottle emitter but perhaps there might be a way to do what you want if you spelled it out a little more. If for example you want a photo of a bottle to multiply, you’d simply drop it into the emitter’s image well.
    Noah
  • Jim Kanter
    September 26, 2005 at 2:20 pm
    Use the Replicator in Motion 2. Make the whiskey bottle the cell image and do a line replicator. You can then animate the end point of the line to stretch the line and reveal multiple cells on the replicator.
  • Sarah
    September 26, 2005 at 8:13 pm
    have been using the replicate in fcp which works well but I was looking to try something a little more dynamic , Noah can you elaborate a little on dropping the image into the emitter’s image well. I have a still image of a bottle that I hope to composite over a animated background, what I was hoping to do was to animated the bottle similar to what you can do with leave in one of the opening templates is this possible
    Thanks for advice
    sarah
  • Doyle Rockwell
    September 26, 2005 at 9:11 pm
    Hey Sarah,
    Take a look at the short replicator tutorial in the Help menu, or even the replicator section of the manual (also found in the Help menu). You’ll have a much easier time of it than slowly beating the steps out of us 🙂
