Activity Forums Apple Final Cut Pro Legacy suggestions for the off-line edit
  • suggestions for the off-line edit
    Posted by Grant Keiner on February 19, 2008 at 10:05 pm
    Hi All,
    I need to off-line a bunch of shows shot in HD 1920×1080 23.976fps. I will ingest HDCAM at some compressed rate then online each hour long show using PRORES HQ.
    Does anyone have suggestions for the off-line edit. I a considering DVCPROHD. photo jpeg. and XDCAM. Has anyone used XDCAM to “offline” in final cut? is this possible? I will ingest using a decklink HD Extreme.
    Does anyone have any other ideas?
    Grant Keiner replied 18 years, 7 months ago 3 Members · 6 Replies
  • Shane Ross
    February 19, 2008 at 11:47 pm
    Use DVCPRO HD. It is the standard for high end offline editing (high end meaning higher end acquistion, like HDCAM SR). Then recapture when picture is locked. DVCPRO HD is an INTER Frame codec, meaning individual frames, like your source footage. XDCAM is INTRA Frame, meaning it contains like 4 real frames, then a bunch of pictures. LONG GOP format…not good for offlining.
    DVCPRO HD 720p 23.98 is your best bet.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Grant Keiner
    February 20, 2008 at 12:00 am
    Shane,
    Would you happen to know if the decklink HD Extreme can capture 1080 and transcode to 720 on the fly?
    -Grant
  • Russell Lasson
    February 20, 2008 at 12:14 am
    I’d suggest using DVCPROHD. It’s very edit friendly.
    Photo-JPEG isn’t supported in RT effects and XDCAM is kind of a pain to edit with because it’s so processor intensive to decode.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Russell Lasson
    February 20, 2008 at 12:26 am
    According to Blackmagic Design, the card can:
    HD Cross Conversion Mac OS X™ only real-time rendering on all HD cards. Support for HD 720 to HD 1080 cross conversion. Click here for the latest cross-conversion features and details.
    https://decklink.com/products/hd/techspecs/
    -Russ
    Russell Lasson
    Provo, UT
  • Grant Keiner
    February 20, 2008 at 12:38 am
    Russ,
    Thanks for the link. I was having trouble finding it on Black Magic’s site.
    -G
  • Grant Keiner
    February 21, 2008 at 11:18 pm
    Thanks For the tip!
    Is there a particular easy setup I need to choose. Or are ther settings I need to change to cross-convert on the fly?
    -G
