Activity Forums Apple Final Cut Pro Legacy Suggestions for setting up a RAID 5 on a macpro
  • Suggestions for setting up a RAID 5 on a macpro
    Posted by Steve Heffner on May 2, 2008 at 5:18 pm
    Hey all,
    I need to setup a RAID 5 for a cutter. Right now we just have a JOBD setup and backing up sony HDV camera masters to drive one, ingesting via FCP to Drive two (making Quicktime masters) and backing up on drive 3.
    The editor wants to start cutting next week. So, we have to convert this four drive tower to a RAID 5 (with four 1 TB drives).
    I do NOT want to erase what we’ve got on these current drives. So, do we need to get a second tower and set that up as the true raid for him to work off of? Or can we copy all of the source/master media to the internal, load 4 new TB drives to the 4 slot bay, config as a RAID 5 and then drag all the master footage back to drive 1?
    The only thing I’m not clear on is then, what drive because the Parody Data drive in case of failure? Will that be determined in the raid hardware/software setup config?
    Sorry, this is new territory for me so any guidance would be helpful.
    One more thing: If we only use this one tower but find ourselves needing to go to some files on one of our random drives we are using now, can it be hot swapped out so we can drag and drop the files or should we avoid that altogether?
    Thanks in advance…
    Steve
    Sean Oneil replied 18 years, 4 months ago 5 Members · 10 Replies
  • 10 Replies
  • David Roth weiss
    May 2, 2008 at 5:50 pm
    Steve,
    Setting up a homemade Raid-5 can be done, but its never as easy, as safe or as reliable as buying one setup from a manufacturer. I strongly suggest that you should not expect to be able to order the right parts, assemble them and fully master the art of raid-5 perfectly in one week’s time.
    Raid-5 is all about safety, and if you are not fully able to test and retest your homemade solution, your raid-5 setup could very easily be far less safe than any raid-0 zero solution.
    If your heart is dead set on the mission, check out the the solutions that are tested on AMUG such as the one Scott Thomas discusses in his Cow post at https://forums.creativecow.net/readpost/8/983651
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Jared Picune
    May 2, 2008 at 7:12 pm
    Steve,
    I would recommend going with the CalDigit RAID Card. Frankly it’s only $549, and will make your life much easier.
    It’s 100% hardware RAID, which is very important, bootable, and you can migrate your data. Which sounds like it will be important to you. Also you can expand up to 16 total drives.
    https://www.CalDigit.com/RAIDCard/
    Check it out If you have any additional question I’ll be happy to help you out over on the CalDigit Forum.
    https://forums.creativecow.net/forum/caldigit
    Also to answer your question about parody. With RAID 5 use this formula: Subtract 1 drive. Very easy.
    Jared Picune
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
    Geeky Mac | FCP Tips & Tricks
  • Sean Oneil
    May 3, 2008 at 1:03 am
    Steve,
    What is your current JBOD tower plugged into? Is is a hardware RAID controller?
    Sean
  • Sean Oneil
    May 3, 2008 at 1:11 am
    David,
    That’s great advice for someone who hasn’t bought anything yet. But he already has four 1TB drives and an external enclosure set up. And his controller card might already support RAID-5 (he didn’t say what he was using). It would be a huge waste of time and money not to use his existing equipment.
    RAID-5 isn’t tricky to set up or anything. On just about any controller all you need to do is pick the block size (just like in RAID-0) and make sure write caching is enabled.
    Sean
  • David Roth weiss
    May 3, 2008 at 1:23 am
    Sean,
    There were a few things Steve said in his original post that concerned me and I simply didn’t want to him jump into something over his head that could potentially create more problems than it solved. Raid-5 that doesn’t work as expected has none of the benefits of Raid-0 and instills a false sense of security that can be devastating.
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Walter Biscardi
    May 3, 2008 at 3:42 am
    [David Roth Weiss] “Setting up a homemade Raid-5 can be done, but its never as easy, as safe or as reliable as buying one setup from a manufacturer.”
    I would highly recommend this as well because if something goes wrong, well then you have to figure out what’s wrong. If you purchase a pre-built RAID 5 from a manufacturer then you get tech support to assist with installation and any issues that might arise.
    Storage is one place I never build my own solutions, I always purchase pre-built and it has paid great dividends over the years with tech support.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • David Roth weiss
    May 3, 2008 at 3:53 am
    [walter biscardi] “Storage is one place I never build my own solutions, I always purchase pre-built and it has paid great dividends over the years with tech support.”
    I have no problem building Raid-0 arrays because you don’t expect them to be mission critical, but Raid-5 really has to be mission critical.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Steve Heffner
    May 3, 2008 at 3:00 pm
    Thanks everyone, thus far.
    Sean,
    Yes, the editor told me the tower is plugged into a controller. I want to see it for myself so I’m going down there today. I am not sure what controller it is so I will find out and post.
    He’s saying stuff like,”all we’ll have to do is jut format the RAID” but to me nothings is ever that simple and since I haven’t done this before and I’m the assistant, I’m just being cautious and anal retentive and want to have as much info as I can so I can ask HIM questions and give some directives so we don’t end up with a potential catastrophe.
    He’s working with HDV footage and we will always have our tapeless footage backups backed up (and master tapes) in case of a major failure or something.
    So, if the controller is set then I’m assuming we could just set the raid up through the controller and he’s good to go?
    Steve
  • Steve Heffner
    May 3, 2008 at 3:04 pm
    Jared,
    Thanks and will do.
    Steve
  • Sean Oneil
    May 3, 2008 at 6:07 pm
    If it’s a hardware RAID card and it supports RAID-5, yes, that’s all you need to do.
    But if this was software RAID, done in disk utility, then you cannot do RAID-5. There is no software RAID-5 for a Mac.
    Sean
