Activity › Forums › Apple Motion › Suggestions for Quick(ish) Rotoscoping
  • Suggestions for Quick(ish) Rotoscoping
    Posted by Tangier Clarke on March 7, 2019 at 4:25 pm
    I am trying to mask someone from the foreground sitting in front of an iMac (iMac takes up most of the frame while subject is frame right partially covering screen) so I can put something on the iMac screen. Is the Track Points behavior the most capable way of tracking a shape mask? It does’t seem like tracking points is the same as tracking a shape over time. I’ve been looking into using DaVinci’s Fusion for this as well as CoreMelt Slice X, but am trying to see if there’s a way in Motion to do this effectively.
    Motion 5.4.2
    Robin S. kurz replied 7 years, 6 months ago 3 Members · 4 Replies
  • Mark Spencer
    March 7, 2019 at 7:42 pm
    You’ll likely have to keyframe the mask points and/or mask position. You can technically track the mask but likely easier to just keyframe.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Tangier Clarke
    March 7, 2019 at 9:52 pm
    Thanks Mark. I converted everything to 3D and although it worked in Motion, the published Z parameter had no effect in FCP X.
  • Mark Spencer
    March 7, 2019 at 10:01 pm
    Sorry to hear that. I did not test it first. In theory should work….not sure what else to suggest.
    Mark Spencer
  • Robin S. kurz
    March 8, 2019 at 11:16 am
    Could it be you’re mixing threads here? ????
    Assuming we’re talking about the issue from the other thread, the 3D + Z coordinates should definitely work, yes. Just tried it. Works as expected. You must be missing something.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
    Youtube | Facebook
