Activity Forums Apple Final Cut Pro Legacy suggestions for Mini DV deck “pro-sumer” is fine
  • suggestions for Mini DV deck “pro-sumer” is fine
    Posted by scottwitt Scott witt on September 2, 2010 at 1:50 pm
    Any suggestions for a prosumer deck?
    I have used the Panasonic AG-DV1000p for about 6 years and it finally started to eat tapes.
    All I need is SD playback that has analog in and recogniozes FW all time everytime unlike some JVC models i Have used.
    David Johnson replied 16 years ago 3 Members · 3 Replies
  • David Johnson
    September 2, 2010 at 2:40 pm
    A friend of mine uses a Sony GV-HD700 for that purpose and swears by it. I think they retail around $1k, so you might be able to find a used one for half that or less. It’s an HDV deck that’s mini-DV compatible so that’ll give it longer life than a straight mini-DV deck.
    BTW, personally, I hated every JVC deck I’ve ever had to use … just my two pence.
  • Mick Haensler
    September 2, 2010 at 5:12 pm
    Sony DSR-11. Not cheap but very reliable and has yet to not see Firewire. It does have some sync issues when using Firewire though.
    Mick Haensler
    Higher Ground Media
  • David Johnson
    September 4, 2010 at 1:02 am
    I just stumbled across this post from the Classifieds forum:
    https://forums.creativecow.net/readpost/38/867346
    Sounds like a steal to me.
