Activity › Forums › Apple Final Cut Pro Legacy › Suggestions for good offline resolution
  • Suggestions for good offline resolution
    Posted by Paul Huppe on September 22, 2005 at 3:36 pm
    I’ve got a AJA Kona card for digitizing from a BetaSP deck. I’m trying to minimize the file sizes on my lo-res footage. I’ve tried the Photo-Jpeg codec, but at full frame size it’s larger than the DV codec, and I don’t want to reduce the frame size for viewing purposes.
    I’ve tried using the DV codec, and reducing the quality in the compression settings. It gives me the file size I want; however, I get the red render bar in the timeline, even thought the sequence settings are identical to the capture settings.
    Any suggestions?
    Paul
    Jerry Hofmann replied 21 years ago 2 Members · 1 Reply
  • Jerry Hofmann
    September 23, 2005 at 1:43 pm
    If you are happy with DV as your offline format, you shouldn’t have to render at all using the stock presets for it. Kona 2 to DV, and then using Apple’s or the Kona 2’s DV setting for the sequences… So if this is what you are doing and you still have to render, then trash your preference file for FCP and give it another go.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
