Activity Forums Apple Final Cut Pro Legacy Suggestions for consolidating and backing up a project?
  • Suggestions for consolidating and backing up a project?
    Posted by Peter Weis on July 22, 2009 at 8:35 am
    Can any one give me some pointers on consolidating the used sub clips in a project and moving them so they can be backed up with the final cut project and moved off the HD.
    I would like to back up the final cut project and only the used sections of the captured video.
    I would like to archive the raw capture on a regular playable dvd.
    Production Music, Composer, Audio Engineer
    https://www.gnxmusic.com
    Dennis Leppell replied 17 years, 1 month ago 3 Members · 2 Replies
  • Dino Vince
    July 22, 2009 at 2:19 pm
    Backing up projects for me, depends on the combined file size of the raw footage and of the finished sequence. If small enough to fit on a DVD-R, I make quicktime backups of:
    The finished sequence
    The finished sequence without music
    If the finished sequence is too large to fit on one DVD….I export sections at a time.
    I consider the source as the backup for the raw footage. If you don’t have too much media captured, you can select all of the clips in a bin….lay them on a timeline, then export as a Quicktime and write to DVD-R
    Don’t encode a video DVD though…encoding compresses the media, and you’ll lose quite a bit of quality if you try to use the media from an encoded DVD in the future.
    Good luck!
  • Dennis Leppell
    July 22, 2009 at 4:36 pm
    I’d add the project file itself to the dvd backup with the finished sequence, so if another editor ever has to make changes, the log/capture info is available, as well the ability to see all filters/transition settings used.
