Activity › Forums › Adobe After Effects › Suggestions for 3D particle effects for fire, smoke, explosions, falling water, etc.
Posted by Eric Goldstein on November 18, 2005 at 11:22 pmHi,
Does anyone have any suggestions for AE plug ins to create realistic fire, smoke, explosions,
falling water, etc.?Thanks for your help,
Eric
Eric Goldstein
Giraffe Film Company
Los Angeles
eric@giraffefilm.comTom Daigon replied 20 years, 10 months ago 5 Members · 12 Replies -
Tom Daigon
November 19, 2005 at 12:22 amStand alone Particle Illusion 3 is spectacular ffor all the above. Soon to be a plugin for AE…See wwww.wondertouch.com.
Eric Goldstein
November 19, 2005 at 12:54 amThanks for the info. Any idea when the AE
plugin will be available?Eric
Eric Goldstein
Los Angeles
eric@giraffefilm.com -
Tom Daigon
November 19, 2005 at 4:44 amIt was originally promised on June 26 ….so I wont even hazard a guess. The company is thriving and PI3 is great for stuff even as a stand alone program.
Eric Goldstein
November 19, 2005 at 6:42 amThanks for the info. Any other suggestions? I’m working on a project
and need something now.Thanks,
Eric
Eric Goldstein
Los Angeles
Naveen Mallikarjuna
November 19, 2005 at 2:19 pmI’ve used Trapcode Particular for smoke effects, and it’s worked pretty good. Be prepared to have A LOT of RAM or time for the rendering.
Eric Goldstein
November 19, 2005 at 6:16 pmThanks everyone for the suggestions.
Eric
Eric Goldstein
Los Angeles
Aharon Rabinowitz
November 20, 2005 at 10:23 pmparticleIllusion standalone works very well with AE. Download a trial from wondertouch.com to give it a shot. It comes with over 1300 preset effects, which particular doesn’t come close to. Not that particular is a bad plug-in – it’s pretty good, but you need to build almost everything from scratch. pIllusion will give you what you need in minutes if not seconds.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Eric Goldstein
November 21, 2005 at 7:07 amThanks for the suggestion. Are you at a disadvantage working with Particle Illusion in that
it is not incorporated in AE in terms of modifying the effect directly in your comp?Thanks,
Eric
Eric Goldstein
Los Angeles
