Activity Forums VEGAS Pro Suggested render settings advice
  • Suggested render settings advice
    Posted by Matt Paul on November 16, 2011 at 2:34 am
    I have a project which is 153 minutes in length. I have rendered this using the HDV 720-25 video setting and Stereo DVD AC-3 audio. The total project size is 9.7GB when imported into DVDA.
    There must be a way to fit the entire video on a single DL DVD (8.5GB). Can someone please advise the suggested render settings. I realize I may lose some quality but it is only a dance concert and not overly critical. If I am not happy with the quality I can always revert to 2 discs but really don’t want to.
    Mike Kujbida replied 14 years, 9 months ago 4 Members · 3 Replies
  • Erik Davis
    November 16, 2011 at 5:39 am
    You need to reduce the bit size of the render. You would do this when you “customize” the template that you are rendering currently. You can manually enter a smaller number that is currently there to reduce the size of the file.
    Erik
  • Bob Peterson
    November 16, 2011 at 1:56 pm
    I suggest a search of the forum for discussions about using a bit rate calculator. This subject has been discussed many times.
  • Mike Kujbida
    November 16, 2011 at 2:09 pm
    Since this is going on a regular DVD and not a Blu-ray, you’re going to have to render the video again using the DVD Architect Pal video stream or DVD Architect Pal widescreen video stream template which will have to be customized as you can;t give it an HD file, only SD.
    I always recommend using the bitrate calculator found at https://www.johncline.com/bitcalc110.zip and the customize it as follows.
    Click the Settings button on the main screen, set the Safety Margin to 5% (default is 1%) giving you some extra room, set the audio to 192 Kb/s AC-3 (this is the default for Vegas) and set 1 kilobit = 1000 bits.
    Exit this screen, set the video to the DVD-9 option, enter 2 hr. 33 min. and click VBR.
    You should get 4064 / 6768 / 8464 (or close to it).
    Render your project again using the appropriate template given above, click the Custom button, click the Video tab (if you’re not already one it), enter these numbers in the appropriate spot (you will need to add 000 to each set of numbers), select the 2-pass mode (takes longer but is worth it) click OK and start rendering.
    Make sure to give it the same name as your audio file and render it to the same folder.
    That way, when you load the video into DVDA, the audio will automatically follow.
