Activity Forums Apple Final Cut Pro Legacy Suddenly lost keyboard shortcuts…
  • Suddenly lost keyboard shortcuts…
    Posted by Clay Stanton on August 27, 2005 at 12:55 am
    Hi I’ve just learned to use keyboard shortcuts and have been all excited putting in some serious hours.
    All of a sudden, I’ve lost the ability to use some of the shortcuts. For instance when I mark a clip in the timeline with I and O.. I can no longer ‘SHIFT+DELETE’… when I do, it just clears the marks. It does not delete.
    This is the strangest thing because it only happens on one project. I thought I was pressing the wrong keys but I opened up another project and the shortcuts work fine.
    On this ‘affected’ project I can’t even do the delete from the menu. The only way to do it now is to drag the clip and shorten it from the edge. Or razor blade and delete the subclip.
    Any help please?
    Clay Stanton replied 21 years ago 3 Members · 4 Replies
  • Jerry Hofmann
    August 27, 2005 at 2:13 am
    Try trashing your preference file for FCP…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Walter Biscardi
    August 27, 2005 at 12:02 pm
    [newschool] “On this ‘affected’ project I can’t even do the delete from the menu. The only way to do it now is to drag the clip and shorten it from the edge. Or razor blade and delete the subclip.”
    In addition to Jerry’s advice, save the project as a new name or even open a New Project and drag all the elements from the original to the new one. It’s possible your project got corrupted.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Clay Stanton
    August 27, 2005 at 3:59 pm
    Thanks to both of you guys.
    I wasn’t sure about finding the prefs files so I tried Walter’s suggestion – creating a new project and coying everything over.
    Got my shortcuts back!
    Such a simple solution. Thanks again!
  • Clay Stanton
    August 27, 2005 at 4:09 pm
    Update: I found the preference files. Deleted them. And nothing has changed. The original project still has that problem/bug. Can’t Ripple Delete.
    Strange!!
    Anyway, I have the new project which seems fine so I’m ok.
