Activity Forums Adobe Premiere Pro Sudden Render Problem (Snow)
  • Sudden Render Problem (Snow)
    Posted by Angel Nieves on August 24, 2018 at 4:01 pm
    This just started happening. I try to export or render, and I get glitches/snow instead of the image. When I go to the export window (see screengrab below), the image is distorted. The glitches/snow also appear on the exported movie file. I’ve been using this version of Premiere (2017) for over a year and never had any problems. This is happening with different projects, including projects I had exported in the past with no problems.
    Angel Nieves replied 8 years ago 1 Member · 1 Reply
  • Angel Nieves
    August 24, 2018 at 6:07 pm
    I figured it out. What worked for me is going to File/Project Settings/General and on the Video Rendering and Playback pull-down menu select switch to ‘Mercury Playback Engine Software Only.’
