Activity › Forums › Adobe After Effects › Sucking Particles
  • Sucking Particles
    Posted by Imhere460 on February 8, 2007 at 4:27 am
    I am currently trying to make a group of particles to be thrust out from a layer and as they slowly move towards the screen I want to get all of the particles to be sucked into one point. Is this possible? Appreciate your time!
    Steve Martin replied 11 years, 5 months ago 6 Members · 5 Replies
  • Mike Clasby
    February 8, 2007 at 5:01 am
    Methinks you should fool around with Distort>CC Flo Motion, and maybe a few masks to clean up spills (you’ll see what I mean. This plugin really sucks, in a good way (crank up the Amount 1 or 2).
  • Colin Braley
    February 8, 2007 at 5:07 am
    What particle system are you using?…If you are using Particular I don’t *think* this is possible, however I can’t speak for other particle systems like Particle Playground. You can do things like this fairly easily in Maya, however.
    ~Colin
  • David Bogie
    February 8, 2007 at 6:15 pm
    Be aware that trying to reverse-program the physics of any particle system is difficult. They’re all designed to thrust and spew, not suck and chew.
    bogiesan
  • Alerad
    February 8, 2007 at 9:26 pm
    Trapcode Particular has a setting in ‘Physics/Air/Spherical Field/Strength’ when set to a negitive value it will suck particals.
    I used it when slowly turning text to smoke then quickly sucking the smoke away.
  • Steve Martin
    April 21, 2015 at 11:22 pm
    This is exactly what i’m trying to accomplish.. could you by any chance give me step-by-step instructions on how i am to achieve
