Activity Forums Adobe After Effects sucking layers in to a point
  • sucking layers in to a point
    Posted by Craig Hellen on July 11, 2013 at 8:31 am
    Hi Guys n Gals
    So I have been struggling with particular on a separate thread and i cant get it working so here’s a follow up question.
    If i wanna suck a load of layers into a point in a spiral vacume motion as if looking down on the central point, how best would i do that, if i have around 60-80 layers (duplicates of 6 original layers)
    This needs to be done WITHOUT particular as i just cant get it working right, i think it’s my gfx card, but thats a separate discussion.
    Please see my mock up showing the motion required.
    Ideally i would have the option to have the layers be fixed in their own rotational axis.
    Suggestions?
    Co-Director Podchains Ltd
    Video Producer / Motion graphics designer https://bexmedia.net
    Craig Hellen replied 13 years, 1 month ago 3 Members · 3 Replies
  • Matthew Keane
    July 11, 2013 at 9:49 am
    If the movement towards the centre is fairly smooth, you could parent your layers to a null at the centre, which would rotate to give the circular motion, and then scale the null down to make the layers move in a spiral. If you want the child layers to stay upright and the same scale, you could add a couple of expressions to invert the rotation from the parent null, and compensate for the scaling down.
    Alternatively, if you want the motion to look a bit more organic and random, you could look at the Newton script on aescripts.com – version 2 had a magnetism feature which could do what you want.
    Matthew Keane
    Freelancer based in Paris, France
    – Motion Graphics, Video Editing & Effects, Watchout Programming & Live Operation.
  • Tudor “ted” jelescu
    July 11, 2013 at 11:31 am
    ShapeShifter AE can do that quite easily with no need for layer duplication. Just apply SSAE to each of the 6 layers, use Generator to multiply and offset your instances in a spiral and animate the position and scale.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Craig Hellen
    July 11, 2013 at 12:13 pm
    Thanks guys will be tryoing this after lunch, the comp is coming on nicely.
    Many thanks for the continued support!
    Craig
