Activity › Forums › Apple Final Cut Pro › Such a weird glitch, but BIG impact on editing ☹ Any insight??
  • Such a weird glitch, but BIG impact on editing ☹ Any insight??
    Posted by Miranda Mendelson on October 16, 2018 at 3:35 pm
    I recently tried updating to Mojave, but got stuck for hours and couldn’t get out of it, even after restarting. Last resort had to restore a time machine backup from the previous day.
    Everything looked fine, but the first thing I opened was FCPX and I noticed something weird. In the viewfinder and while scrubbing, all my footage looked dark– blacks crushed, highlights blown out. But if I just looked at the rows of files without scrubbing, they looked fine.
    This is NOT what the original file looks like, and when I export from FCPX, it looks normal too. But all my libraries and projects look like this now, which is making color correcting impossible since I don’t know what it actually looks like until I export it.
    I did some googling and even came across some old old threads on this forum, found that some people on FCP 7 had this issue but no real solutions posted. There were a few saying fixing the gamma correction in the playback settings worked, but I’m not seeing that option in FCPX playback settings.
    Also, I completely deleted & reinstalled just in case it was a time machine issue– same issue happening.
    Any insight would be greatly appreciated! Nothing else on my screen or other apps are discolored, so I don’t think it’s my actual iMac display settings (tried that anyway).
    Winston A. cely replied 7 years, 11 months ago 5 Members · 11 Replies
  • 11 Replies
  • Scott Witthaus
    October 16, 2018 at 5:00 pm
    This maybe way off, but what is the setting under the View dropdown at the top right? Better performance or better quality?
    Scott Witthaus
    Visual Storyteller – FCPX, Premiere
    https://vimeo.com/channels/1322525
    Managing Partner, Low Country Creative LLC
    Professor, VCU Brandcenter
  • Miranda Mendelson
    October 16, 2018 at 5:02 pm
    I had it on better performance, but I’ve toggled that setting already and nothing changed ☹
  • Steve Connor
    October 16, 2018 at 5:06 pm
    I wonder if FCPX has added a LUT to your footage?
  • Miranda Mendelson
    October 16, 2018 at 5:07 pm
    I found that setting when I was poking around, and nope– it’s set to None. And ADDING any of the LUT options makes it worse.
  • Steve Connor
    October 16, 2018 at 5:43 pm
    Did you trash prefs when you reinstalled?
  • Miranda Mendelson
    October 16, 2018 at 5:45 pm
    I trashed the Final Cut Pro folder in the Library, the “com.apple.FinalCut” folder in the Caches folder, and the following files from Preferences:
    com.apple.FinalCut.LSSharedFileList.plist
    com.apple.FinalCut.plist
    com.apple.FinalCut.UserDestinations.plist
  • Eric Santiago
    October 16, 2018 at 6:13 pm
    Have you tried a fresh install?
    Not a big fan of Time Machine for application installs.
  • Miranda Mendelson
    October 16, 2018 at 6:14 pm
    Yep! as said in orig post, I tried a fresh reinstall and that didn’t fix the problem :/ reinstalled from mac app store
  • Eric Santiago
    October 16, 2018 at 6:55 pm
    Shot in the dark but how about changing your displays color profile?
  • Miranda Mendelson
    October 16, 2018 at 6:57 pm
    last line of original post– tried that, didn’t work. nothing else on my screen is discolored. and I can see the true color in the timeline.
