Activity Forums Apple Final Cut Pro Legacy Success w MacBookPro/ExpressCard34?
  • Success w MacBookPro/ExpressCard34?
    Posted by Sherwood Ball on December 6, 2008 at 12:55 am
    Aloha,
    I’m thinking of buying one of the latest round of MacBookPros
    and want to use my Sata drives for FCStudio.
    Anyone have any success with a particular brand/model Express card?
    Also, any problems running FCStudio with Leopard and MacBookPro?
    Any do’s or don’t’s advice?
    Thnx,
    Sherwood
    OSX.4.11
    Dual 2.7 Ghz PowerPC G5
    8 GB DDR SDRAM
    Sata Card
    Sata II Drives
    MOTU 2408 mk 3
    FCPro 5.1.4
    AE CS3 8.02
    PS CS3 10.0.1
    Logic Pro 8.0.2
    Nathan Alber replied 17 years, 9 months ago 4 Members · 3 Replies
  • Nate Stephens
    December 6, 2008 at 3:26 am
    I am using an Addonics Sata Express card with no problems.. They were the low price leader when I got it.
    No problems at all running Leopard and FC on my Mac Book Pro using the sata express card or the firewire express cards…
    FCP, Mac Pro, Mac Book Pro, HPX500, HVX200, Betacam, Dvcam
    Write for the Edit, Shoot for the Edit, Edit…..KISS Principle
  • Baz Leffler
    December 6, 2008 at 3:29 am
    Gudday Sherwood
    I use a MacBookPro 2.5 Ghz Intel Core 2 Duo and the latest FCS 2/Leopard and have no problems at all (I also run bootcamp/Vista on it)
    I use a eSATA II 300 Express Card adapter that has 2 x eSata connections with it and it works gr8 as well.
    The workflow I use with the MacBookPro and the Sony Ex1 is that I plug in the Sony SxS into the express card slot and the eSata external drive into the firewire connector (they have multiple interfaces) and move all my data off the SxS into organised folders. Then I remove the SxS card and insert the eSata Express Card adapter and plug the eSata drives into that and edit away.
    When I need to run totally battery I use a Lacie Rugged drive and connect via FW800 but I can also plug a 12 volt battery pack into the eSata external drive if I need to – I just like to keep the wiring spiderweb down to a minimum!
    I have a big job coming up soon where I need to do location playouts into a network feed and I am tossing up between Aja ioHD or the Matrox MXO – one runs on batteries and the other doesn’t but one uses the Express card slot and the other uses the FW800 so my decision will probably be based on what I need with connectivity but both can do HD-SDI which is what I need.
    Baz
    What would I do without the ‘UNDO’ button!!!!
  • Nathan Alber
    December 6, 2008 at 8:41 pm
    i have a SIIG Express34 FW800 card that i’ve been using for about 11 months now. I’ve had no problems with it in my MacBook Pro.
