Activity Forums Adobe After Effects Subtracting ellipse not working as expected
  • Subtracting ellipse not working as expected
    Posted by Rob Alderman on December 15, 2010 at 10:59 am
    Hi All,
    This is my first post although I have read a lot of the threads over the past few months as I have been learning to use Final Cut Pro and Adobe After Effects. Great forum from what I have experienced so far.
    I have only just started to learn how to use Adobe After Effects so just to warn you, I am at a basic level!
    I was running through the following tutorial (https://vimeo.com/7311185) and got to the part when he was adding the “Pin hole” effect using the ellipse solid tool. He adds the soild, creates an ellipse shape and then uses the ‘Subtract’ function and then the feather function to create a pin hole style effect.
    When I do this, the ellipse goes on fine but when I click ‘Subtract’, the ellipse disappears and doesn’t “invert” as expected. I’ve tried to find information on the net and on here but to no avail.
    Can anyone help?
    Rob.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Spaceman —> replied 15 years, 8 months ago 2 Members · 1 Reply
  • Spaceman —>
    December 16, 2010 at 4:00 pm
    SPACEMAN has tried this. SPACEMAN is wondering if you have created a black layer and also an ellipse shape layer? Create an elliptical mask on the black layer and choose “subtract”. If this is still not working, try clicking the “inverted” check box and choosing “add” from the mask drop down menu.
    SPACEMAN needs spaceship parts, not expressions…
