Activity Forums Maxon Cinema 4D subtract and intersect in c4d
  • subtract and intersect in c4d
    Posted by Pablo Hill on November 25, 2007 at 6:29 pm
    My 3d background comes basicaly fron lightwave, and i’m having a hard time finding something that can replace the subtact, add, and intersect tools.
    thanks
    Adam Trachtenberg replied 18 years, 10 months ago 3 Members · 9 Replies
  • 9 Replies
  • Nolan Scott
    November 25, 2007 at 10:43 pm
    You might like and try a Boolean-Object.
    (Objects / Modeling / Boole)
    Cheers
    Nolan
  • Pablo Hill
    November 26, 2007 at 3:03 pm
    that’s what I was looking for….Thanks
  • Pablo Hill
    November 26, 2007 at 5:45 pm
    For some reason the booleans are not working properly, this is a simple text with some lights and textures and for some reason it’s not registering some letters and it’s making my computer very slow.
    At first glance I thought it was way better than Lightwave booleans since they were non destructive, and I don
  • Adam Trachtenberg
    November 26, 2007 at 6:39 pm
    The pic isn’t showing up here….
  • Pablo Hill
    November 26, 2007 at 10:46 pm
    Are U sure???? I can see it perfectly form here…
  • Nolan Scott
    November 26, 2007 at 10:54 pm
    Using Cinema R10.5 / iMac G5 (Intel) / OSX 10.4.11
    Well, regarding your image (viewable with Safari),
    I really have no idea why some of your letters are not showing up.
    I just did a test with
  • Adam Trachtenberg
    November 26, 2007 at 10:56 pm
    [Pablo Hill] “Are U sure???? I can see it perfectly form here…”
    I’m sure, unless it’s a render of a little red x.
  • Pablo Hill
    November 26, 2007 at 11:08 pm
    Found the problem, It happens when you use fillet and caps on the text.
  • Adam Trachtenberg
    November 27, 2007 at 2:59 am
    [Pablo Hill] “Found the problem, It happens when you use fillet and caps on the text.”
    Probably using too wide a fillet, which is easy to do with narrow/fancy fonts.
