Activity Forums Apple Final Cut Pro Legacy Subtle frame rate effects
  • Subtle frame rate effects
    Posted by Wayne Williams on March 13, 2010 at 1:48 pm
    I am working on a project to create a silent film look. In particular I am after capturing the effect associated with the frame rate variability inherent in capturing with crank cameras, within maybe one to two frames, and their projection at similar, or slight higher rates.
    I am not after an exaggerated sped up effect, rather that the motion looks “crisp” with subtle variability in perceived frame rate, Buster Keaton’s The General is a perfect example.
    Any thoughts on how to go about this?
    Wayne Williams
    Portland Oregon
    Jerry Hofmann replied 16 years, 6 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    March 13, 2010 at 4:45 pm
    Maybe a very subtle set of variable speed changes would do it…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
