Activity Forums Adobe Encore DVD subtitles: wont import txt.
  • subtitles: wont import txt.
    Posted by Chris Balogh on March 18, 2010 at 7:30 pm
    I have used the subtitle workshop for start and end times for subtitles…it creates a txt file literally designed just for ENCORE, i HAVE CS4 ENCORE. It will not import it throws up a window stating: THE SOFTWARE THATS USED TO DECODE THE MEDIA IS NOT AVAILABLE ON THIS SYSTEM. INSTALLING THE CORRECT DECODERS FOR THE FILES YOU ARE WORKIGN WITH MAY HELP…WHAT DO I DO NOW HELP?!
    THANKS
    Minu Sharma replied 16 years, 3 months ago 2 Members · 1 Reply
  • Minu Sharma
    May 14, 2010 at 6:12 am
    Hi Chris,
    Encore accepts subtitles in UTF-8 format . You can save your subtitle file in subtitle workshop as ” Save as Encore subtitles”.
    This file will be imported fine in Encore .
    Please respond if that solved your issue.
    Minu
