Activity › Forums › Adobe After Effects › subtitles with effects
  • Roland R. kahlenberg
    February 21, 2014 at 10:57 am
    What’s preventing you from applying effects?
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Valerio Zanini
    February 21, 2014 at 12:24 pm
    The problem is that I want automate the process for all subtitles; I would like to add the effects for all subtitlel without to add keyframes manually..which
    part of code of the script I have to modify?or which lines of code javascript I have to add?
    thanks for your time! 🙂
    Valerio
  • Kevin Camp
    February 23, 2014 at 6:10 pm
    i’m not a script guy, but you may be able to use expressions for this.
    the script looks like it writes a keyframe each time it changes the text. using expressions you can detect the keyframes on the source text property to drive change in another property.
    this example (pasted in the opacity property of the text layer) will create a fade in and out at each source text keyframe:
    fadeT = .5; // value in seconds
    n = text.sourceText.nearestKey(time);
    t = Math.abs(time-n.time);
    if (t > fadeT) 100;
    else linear(t, 0, fadeT, 0, 100)
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Valerio Zanini
    February 24, 2014 at 10:23 pm
    I pasted the example code and It works very well! Thank you very much Kevin!
