Activity Forums Adobe Encore DVD subtitles preferred format for encore (and premiere)
  • subtitles preferred format for encore (and premiere)
    Posted by Ginger Gentile on March 13, 2013 at 9:47 pm
    I just finished a 65 minute film and have contracted a subtitling company to do the subtitles in English and Spanish. They have offered to deliver the subtitles in various formats:
    STL, RTF, SUB, PAC, etc..
    Which should I ask for encore?
    Also, I will need to burn the subtitles in premiere pro (some festivals ask for the subtitles to be burned onto a digital master).
    Any recomendations?
    Any things I should watch out for or be aware of?
    I have always done subtitling myself for short films, so first time at this.
    Ginger Gentile replied 13 years, 4 months ago 3 Members · 11 Replies
  • 11 Replies
  • Daniel Ludwig
    March 14, 2013 at 6:26 am
    MAC od PC?
  • Ginger Gentile
    March 14, 2013 at 1:33 pm
    I work on PC, some of the other people working on this work on MAC–if there is a format that works on both, the best.
    The idea is that I will get the subtitles in a format that will then be places in the sequence and automatically go to where they need to go–this exists?
  • Daniel Ludwig
    March 14, 2013 at 8:39 pm
    Ginger,
    there are subtitle-tools for MAC and PC, some are free, some not.
    for example PC-software: https://www.softpedia.com/get/Multimedia/Video/Other-VIDEO-Tools/Subtitle-Workshop.shtml
    for mac you can use annotation edit from zeitanker: https://www.zeitanker.com
    premiere itself could not import/export any subtitle-format because of its title-tool-implementation. you can´t even import FCP-XML and work on the text, simply not possible. annotation edit can generate subtitles that will work within encore.
    zeitanker is also selling the annotation trascriber app, this is for transcription – very easy, 29€ cheap and very good for quick spotting.
    afterwards the project-file could be exported using anntation edit to go to encore – very easy – one klick.
    cheers
    danny
  • Ginger Gentile
    March 15, 2013 at 2:37 pm
    Hi Danny,
    I myself will not be doing the subtitles–I will receive them from the subtitling company, “ready to put in the movie” with the timecodes. They asked me what format I want them, as they can do them in any format–what format should I ask them in?
    Thanks for letting me know that I won´t be able to do subtitles in Premiere, I guess I will need to put them in manually from a text file if I need to burn them into the movie, correct?
  • Daniel Ludwig
    March 16, 2013 at 5:11 pm
    the most easy way is to create a STL-file. but you might be awared that the need to give you the ISO-coding (UTF-8, UTF-16), otherwise it could be possible that special character will not be correct with other languages.
    most subtitle-applications could convert STL to any other format that you need, like the encore-format.
    for example STL looks like this:
    // Format for Spruce Maestro/DVD Studio Pro
    // Title: Track – English Copy
    // Author: No Author
    // Language: English
    // Date: 03/16/13
    // Offset: 00:00:00:00
    // Format: 24p – 24
    $TapeOffset = False
    $FontName = Helvetica
    $FontSize = 23
    $Bold = False
    $Italic = False
    $ColorIndex1 = 7
    $ColorIndex2 = 1
    $ColorIndex3 = 1
    $ColorIndex4 = 0
    $TextContrast = 15
    $Outline1Contrast = 12
    $Outline2Contrast = 6
    $HorzAlign = Center
    $XOffset = 0
    $VertAlign = Bottom
    $YOffset = 0
    $FadeIn = 0
    $FadeOut = 0
    $BackgroundContrast = 0
    $Italic = True
    00:01:10:13,00:01:16:00, You get 50 points for the next question| about Burkina Faso.
    00:01:18:17,00:01:20:05, Ready?| -Yes.
    00:01:21:10,00:01:28:08, What do the farmers in this| village eat for lunch?
    00:01:29:12,00:01:32:03, 1. Nutritious dirt.
    00:01:34:17,00:01:36:08, 2. Beetles.
    00:01:38:08,00:01:40:03, 3. Spaghetti.
    00:01:47:17,00:01:50:00, Number 3, spaghetti.
    while encore-text looks like this, it´s a so called FAB-text:
    1 00:01:10:12 00:01:15:22 You get 50 points for the next question
    about Burkina Faso.
    2 00:01:18:15 00:01:20:04 Ready? -Yes.
    3 00:01:21:08 00:01:28:06 What do the farmers in this village eat for lunch?
    4 00:01:29:09 00:01:32:00 1. Nutritious dirt.
    5 00:01:34:15 00:01:36:05 2. Beetles.
    6 00:01:38:06 00:01:40:01 3. Spaghetti.
    7 00:01:47:14 00:01:49:21 Number 3, spaghetti.
    cheers
    danny
  • Matt Stoddart
    March 19, 2013 at 12:54 pm
    Echoing what Daniel said about asking for an SRT file.
    If you are PC then a great little (free) Subtitling tool, Subtitle Edit3.3.2 ( https://www.nikse.dk/ ) which has the text preset for Encore and loads of other functions.
    You can also ask the company to supply you with a Premiere edl with the corresponding bitmaps which you can import into Premiere if required.
    Matt Stoddart
  • Ginger Gentile
    March 19, 2013 at 3:36 pm
    Great, I will ask for an SRT file and then I can use it for encore and premier, as long as I change it for each program (as I understand, encore needs a heading with information as showed above, while premier doesn´t, it also doenst need line breaks, correct?)
    The only languages I will subtitle for are Spanish and English, so I don´t think I need to worry about asian characters for now.
  • Matt Stoddart
    March 19, 2013 at 4:43 pm
    What you should get from the subtitlers are two lots of files;
    1) SRT – which you can convert into the text file needed for ENCORE.
    2) A Premiere edl file with the accompanying tifs of the subtitles
    If you tell the subtitler you are editing in Adobe Premiere and tell them what frame size and aspect ratio you are working in they will supply the rest.
    The tiff are normally supplied as 4 colour tiffs
    E2 [Outer Edge]…….Color 1
    E1 [Inner Edge]…….Color 2
    PA [Face] …………Color 3
    BG [Background]…….Color 4
    The EDL should link up with all the tifs files , once they are on the timeline just drop the appropriate key effect on the subtitles.
    You can create a Premiere EDL and tifs from a SRT file, but this is normally a function of the more expensive subtitling programmes, Lemony is one of them.
    Do you need the subtitles on the Premiere time line for cutting purposes or just as a reference?
  • Ginger Gentile
    March 19, 2013 at 5:15 pm
    Hi Matt,
    This is my first time finishing up a film–I will burn a dvd where the subtitles are optional in Encore but some festivals ask that the subtitles be burned into the actual film (especially because the spoken language is Spanish) and then presented on DVD, or more likely, digi beta, HD or other support, including a hard drive. So I will be rendering the film on Premier to send then to make the digibeta, HD tapes, etc
    In the past I have only made digibeta tapes of my shorts, and the formats are changing all the time. I know that for cinema releases in Argentina (where the film was made)it has to be presented in 2K.
  • Matt Stoddart
    March 19, 2013 at 5:43 pm
    Ah, I see.. you do need both.
    Matt
